[postgis-users] Ubuntu and Postgresql9.1.3-2
Smaran Harihar
smaran.harihar at gmail.com
Wed May 23 14:13:33 PDT 2012
Thanks for the reply Jeff.
The extensions in my database is only plpgsql. Nothing else. Also I did
not separately install PostGIS. I installed it along with GeoServer using
the Synaptic. The complete list of installed packages are as follows,
1. postgresql 9.1 + postgis 1.5.3
2. postgis 1.5.3
3. postgresql 8.4 + postgis 1.5.3
4. opengeo-postgis 2.4.4
I did not install any from the source as in the wiki link you gave. So If I
remove, which ones should I remove?? Also since I need it to be connected
to Geoserver will removing the package affect the opengeo suite?
Thanks & Regards,
Smaran Harihar
On Wed, May 23, 2012 at 12:45 PM, Jeff Meyer <jeff at gwhat.org> wrote:
> Mean to add this before - it's an image of the Extensions folder in
> pgAdmin III:
> http://s1064.photobucket.com/albums/u361/jeffmegwhat/?action=view¤t=postgisextensions.png
> *From:* Jeff Meyer <jeff at gwhat.org>
> *To:* PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> *Sent:* Wednesday, May 23, 2012 12:42 PM
> *Subject:* Re: [postgis-users] Ubuntu and Postgresql9.1.3-2
> Hi Smaran -
> I can't speak to what went wrong during your install, but have you
> double-checked your ability to add extensions through pgAdmin III?
> You should be able to open your db, navigate to extensions, right click on
> the extensions label, and then click "New Extension." If PostGIS isn't
> listed as a possible extension, then something went wrong in the PostGIS
> install.
> You may want to then do an 'apt-get remove postgis' and then follow the
> instructions at:
> http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS20Ubuntu1204.
> Thanks, Jeff
> *From:* Smaran Harihar <smaran.harihar at gmail.com>
> *Sent:* Wednesday, May 23, 2012 10:09 AM
> Hi,
> I have already installed PostGIS 2.0 and Postgres 9.3.1 using synaptic
> package manager.
> Now when I run your commands in psql console,
> shpRepo=# CREATE EXTENSION postgis;
> I am receiving an error,
> ERROR: could not open extension control file
> "/usr/share/postgres/9.1/extension/postgis.control": No such file or
> directory
> Where did I go wrong?
> On Wed, May 23, 2012 at 9:58 AM, Brian H Wilson <brian at wildsong.biz>wrote:
> On 5/23/2012 8:08 AM, José María Amuedo wrote:
> Someone know how can linstall postgresql-9.1.3-2-linux.run in Ubuntu 12.04?
> I installed it but I can not to launch stackbuilder to configure new
> tools like postgis.
> As Jeff said, installing on Ubuntu 12.04 using apt-get is easy, and I've
> only used stackbuilder once. You don't really need it.
> I like to experiment with the latest so currently I do install PostGIS
> from sources. The version in the official Ubuntu repository is still at
> 1.5.3
> There are instructions here for PostGIS 2 packages that look pretty
> promising:
> My own grueling details are here: http://wildsong.biz/index.php/PostGIS
> Feedback welcome.
> Hope this helps,
> Brian
> ______________________________**_________________
> postgis-users mailing list
> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
> Thanks & Regards
> Smaran Harihar
Thanks & Regards
Smaran Harihar
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120523/a444ebe7/attachment.html>
Name: Screenshot from 2012-05-23 14:08:12.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120523/a444ebe7/attachment.png>
