[postgis-users] Ubuntu and Postgresql9.1.3-2
Jeff Meyer jeff at gwhat.org
Wed May 23 12:45:36 PDT 2012
Mean to add this before - it's an image of the Extensions folder in pgAdmin III: http://s1064.photobucket.com/albums/u361/jeffmegwhat/?action=view&current=postgisextensions.png
>________________________________
> From: Jeff Meyer <jeff at gwhat.org>
>To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>Sent: Wednesday, May 23, 2012 12:42 PM
>Subject: Re: [postgis-users] Ubuntu and Postgresql9.1.3-2
>Hi Smaran -
>I can't speak to what went wrong during your install, but have you double-checked your ability to add extensions through pgAdmin III?
>You should be able to open your db, navigate to extensions, right click on the extensions label, and then click "New Extension." If PostGIS isn't listed as a possible extension, then something went wrong in the PostGIS install.
>You may want to then do an 'apt-get remove postgis' and then follow the instructions at: http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS20Ubuntu1204.
>Thanks, Jeff
>> From: Smaran Harihar <smaran.harihar at gmail.com>
>>Sent: Wednesday, May 23, 2012 10:09 AM
>>Hi,
>>I have already installed PostGIS 2.0 and Postgres 9.3.1 using synaptic package manager.
>>Now when I run your commands in psql console,
>>shpRepo=# CREATE EXTENSION postgis;
>>I am receiving an error,
>>ERROR: could not open extension control file "/usr/share/postgres/9.1/extension/postgis.control": No such file or directory
>>Where did I go wrong?
>>On Wed, May 23, 2012 at 9:58 AM, Brian H Wilson <brian at wildsong.biz> wrote:
>>On 5/23/2012 8:08 AM, José María Amuedo wrote:
>>>Someone know how can linstall postgresql-9.1.3-2-linux.run in Ubuntu 12.04?
>>>>I installed it but I can not to launch stackbuilder to configure new
>>>>tools like postgis.
As Jeff said, installing on Ubuntu 12.04 using apt-get is easy, and I've only used stackbuilder once. You don't really need it.
>>>I like to experiment with the latest so currently I do install PostGIS from sources. The version in the official Ubuntu repository is still at 1.5.3
>>>There are instructions here for PostGIS 2 packages that look pretty promising:
>>>My own grueling details are here: http://wildsong.biz/index.php/PostGIS
>>>Feedback welcome.
>>>Hope this helps,
>>>Brian
>>>_______________________________________________
>>>postgis-users mailing list
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>Thanks & Regards
>>Smaran Harihar
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120523/c5dcb8ed/attachment-0001.html>
