[postgis-users] Ubuntu and Postgresql9.1.3-2
    Jeff Meyer
    jeff at gwhat.org
    Wed May 23 12:42:04 PDT 2012
Hi Smaran -
I can't speak to what went wrong during your install, but have you double-checked your ability to add extensions through pgAdmin III?
You should be able to open your db, navigate to extensions, right click on the extensions label, and then click "New Extension." If PostGIS isn't listed as a possible extension, then something went wrong in the PostGIS install.
You may want to then do an 'apt-get remove postgis' and then follow the instructions at: http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS20Ubuntu1204.
Thanks, Jeff
>________________________________
> From: Smaran Harihar <smaran.harihar at gmail.com>
>To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>Sent: Wednesday, May 23, 2012 10:09 AM
>Subject: Re: [postgis-users] Ubuntu and Postgresql9.1.3-2
>Hi,
>I have already installed PostGIS 2.0 and Postgres 9.3.1 using synaptic package manager.
>Now when I run your commands in psql console,
>shpRepo=# CREATE EXTENSION postgis;
>I am receiving an error,
>ERROR: could not open extension control file "/usr/share/postgres/9.1/extension/postgis.control": No such file or directory
>Where did I go wrong?
>On Wed, May 23, 2012 at 9:58 AM, Brian H Wilson <brian at wildsong.biz> wrote:
>On 5/23/2012 8:08 AM, José María Amuedo wrote:
>>Someone know how can linstall postgresql-9.1.3-2-linux.run in Ubuntu 12.04?
>>>I installed it but I can not to launch stackbuilder to configure new
>>>tools like postgis.
As Jeff said, installing on Ubuntu 12.04 using apt-get is easy, and I've only used stackbuilder once. You don't really need it.
>>I like to experiment with the latest so currently I do install PostGIS from sources. The version in the official Ubuntu repository is still at 1.5.3
>>There are instructions here for PostGIS 2 packages that look pretty promising:
>>My own grueling details are here: http://wildsong.biz/index.php/PostGIS
>>Feedback welcome.
>>Hope this helps,
>>Brian
>>_______________________________________________
>>postgis-users mailing list
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>Thanks & Regards
>Smaran Harihar
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120523/5bae787c/attachment.html>
