[postgis-users] rt_resample test fails on PostGIS 2.0, Debian 6 amd64
Bborie Park
bkpark at ucdavis.edu
Thu May 24 08:19:47 PDT 2012
Antonis,
What verson of GDAL are you running?
-bborie
On Thu, May 24, 2012 at 4:51 AM, Antonis Christofides
<anthony at itia.ntua.gr> wrote:
> I forgot to mention that I'm using PostgreSQL 9.1 (from backports) and
> geos-3.3.3 (custom Debian packaged by me).
> On 2012-05-24 14:44, Antonis Christofides wrote:
>> The subject line says everything. I try to compile PostGIS 2.0 on an amd64
>> Debian 6 (squeeze). ./configure works ok, and so does make, but here's part of
>> the output of "make test":
>> rt_resample .. failed (diff expected obtained: /tmp/pgis_reg/test_51_diff)
>> I attach the test_51_diff file.
>> The problem occurs both on 2.0.0, and on the latest 2.0-branch svn.
>> Am I doing something wrong? Could someone help me get past this problem? Thanks!
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
