[postgis-users] rt_resample test fails on PostGIS 2.0, Debian 6 amd64
Antonis Christofides
anthony at itia.ntua.gr
Thu May 24 04:51:42 PDT 2012
I forgot to mention that I'm using PostgreSQL 9.1 (from backports) and
geos-3.3.3 (custom Debian packaged by me).
On 2012-05-24 14:44, Antonis Christofides wrote:
> The subject line says everything. I try to compile PostGIS 2.0 on an amd64
> Debian 6 (squeeze). ./configure works ok, and so does make, but here's part of
> the output of "make test":
> rt_resample .. failed (diff expected obtained: /tmp/pgis_reg/test_51_diff)
> I attach the test_51_diff file.
> The problem occurs both on 2.0.0, and on the latest 2.0-branch svn.
> Am I doing something wrong? Could someone help me get past this problem? Thanks!
> postgis-users mailing list
