[postgis-users] rt_resample test fails on PostGIS 2.0, Debian 6 amd64
Antonis Christofides
anthony at itia.ntua.gr
Thu May 24 04:44:46 PDT 2012
The subject line says everything. I try to compile PostGIS 2.0 on an amd64
Debian 6 (squeeze). ./configure works ok, and so does make, but here's part of
the output of "make test":
rt_resample .. failed (diff expected obtained: /tmp/pgis_reg/test_51_diff)
I attach the test_51_diff file.
The problem occurs both on 2.0.0, and on the latest 2.0-branch svn.
Am I doing something wrong? Could someone help me get past this problem? Thanks!
--- rt_resample_expected 2012-05-24 09:21:33.000000000 +0000
+++ /tmp/pgis_reg/test_51_out 2012-05-24 10:34:40.562455574 +0000
@@ -11,35 +11,35 @@
1.14|992163|11|11|1|1000.000|-1000.000|0.000|0.000|-500100.000|600950.000|t|t|t
1.15|992163|201|201|1|50.000|50.000|0.000|0.000|-500040.000|589957.000|t|t|t
1.16|992163|84|84|1|121.000|121.000|0.000|0.000|-500093.000|589875.000|t|t|t
-1.17|993310|243|243|1|50.000|50.000|0.000|0.000|950710.000|1397157.000|t|t|t
-1.18|993309|243|243|1|50.000|50.000|0.000|0.000|950760.000|1396957.000|t|t|t
+1.17|993310|248|235|1|50.000|50.000|0.000|0.000|950710.000|1397557.000|t|t|t
+1.18|993309|248|235|1|50.000|50.000|0.000|0.000|950760.000|1397357.000|t|t|t
1.19|992163|10|10|1|1000.000|-1000.000|3.000|3.000|-500030.000|600000.000|t|t|t
1.2|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
1.20|993310|12|12|1|1009.894|-1009.894|3.000|3.000|950691.792|1409281.783|t|t|t
1.21|993309|12|12|1|1009.916|-1009.916|1.000|3.000|950742.107|1409088.896|t|t|t
-1.22|993310|24|24|1|500.000|500.000|3.000|3.000|950657.188|1397356.783|t|t|t
-1.23|993310|26|26|1|500.000|500.000|0.000|6.000|950452.000|1396632.000|t|t|t
+1.22|993310|25|24|1|500.000|500.000|3.000|3.000|950657.188|1397356.783|t|t|t
+1.23|993310|26|25|1|500.000|500.000|0.000|6.000|950452.000|1397132.000|t|t|t
1.24|992163|207|101|1|50.000|-100.000|3.000|0.000|-500319.000|600056.000|t|t|t
1.25|992163|207|101|1|50.000|-100.000|3.000|0.000|-500319.000|600056.000|t|t|t
1.26|992163|150|150|1|66.667|-66.667|0.000|0.000|-500000.000|600000.000|t|t|t
-1.27|993310|150|150|1|80.792|-80.792|0.000|0.000|950732.188|1409281.783|t|t|t
+1.27|993310|150|150|1|82.219|-78.090|0.000|0.000|950732.188|1409281.783|t|t|t
1.28|992163|5|5|1|2064.200|-2291.200|0.000|0.000|-500321.000|601456.000|t|t|t
1.29|||||||||||||
1.3|993309|12|12|1|1009.916|-1009.916|0.000|0.000|950762.305|1409088.896|t|t|t
1.30|984269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
1.31|974269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
1.4|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
-1.5|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
+1.5|993310|25|23|1|500.000|500.000|0.000|0.000|950732.188|1397781.783|t|t|t
1.6|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
1.7|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
1.8|992163|20|20|1|500.000|500.000|0.000|0.000|-500000.000|590000.000|t|t|t
1.9|992163|40|40|1|250.000|250.000|0.000|0.000|-500000.000|590000.000|t|t|t
2.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
-2.10|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
-2.11|993309|121|121|1|100.000|100.000|0.000|0.000|950762.305|1396988.896|t|t|t
+2.10|993310|25|23|1|500.000|500.000|0.000|0.000|950732.188|1397781.783|t|t|t
+2.11|993309|123|117|1|100.000|100.000|0.000|0.000|950762.305|1397388.896|t|t|t
2.12|993310|6|6|1|2000.000|2000.000|0.000|0.000|950732.188|1397281.783|t|t|t
2.13|993310|8|8|1|1500.000|1500.000|0.000|0.000|950732.188|1397281.783|t|t|t
-2.14|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
+2.14|993310|25|23|1|500.000|500.000|0.000|0.000|950732.188|1397781.783|t|t|t
2.15|993310|16|16|1|750.000|750.000|0.000|0.000|950732.188|1397281.783|t|t|t
2.2|993309|12|12|1|1009.916|-1009.916|0.000|0.000|950762.305|1409088.896|t|t|t
2.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
