[postgis-users] PostGis Raster and GDAL 1.9
Jorge Arevalo jorgearevalo at libregis.org
Mon May 28 01:07:09 PDT 2012
David, could you please attach the original files? Seems to be a
problem with the way the driver gets the origin of the raster
coverage, yes.
The code in GDAL trunk is under development. Slowness problem is one
of the reasons.
Best regards,
Jorge
On Tue, May 22, 2012 at 7:01 PM, David B�langer <belanger_david at live.ca> wrote:
> Hi,
> I did tests and all gave the result expected. It seem to be a problem with
> the origin of the result file (see attached file). The application has taken
> the origin of the file 056n05_0100_deme.tif instead of the origin of the
> file 056n05_0100_demw.tif. What do you think ?
> For your information the files are in geographic coordinate system.
> David
>> From: Pierre.Racine at sbf.ulaval.ca
>> To: postgis-users at postgis.refractions.net
>> Date: Tue, 22 May 2012 11:37:03 -0400
>> Subject: Re: [postgis-users] PostGis Raster and GDAL 1.9
>> I would maybe do some tests:
>> 1) Remove the -a_nodata "-32767" parameter. Why did you have to set it? Is
>> the nodata set properly in PostGIS for all rows?
>> 2) Extract one file at a time with mode=2 and then with mode=1
>> Pierre
>> > -----Original Message-----
>> > From: postgis-users-bounces at postgis.refractions.net
>> > [mailto:postgis-users-
>> > bounces at postgis.refractions.net] On Behalf Of David B?langer
>> > Sent: Tuesday, May 22, 2012 10:25 AM
>> > Hi Pierre,
>> > Yes I have a unique rid (Integer) with sequential number. I used the
>> > tool
>> > raster2pgsql.exe to upload the data in the database. I uploaded 2 files
>> > "C:\Program Files\PostgreSQL\9.1\bin\raster2pgsql.exe" -I -e -Y -F -s
>> > 4269
>> > e:\dir\*.tif dbelange.elevationTest | "psql.exe" -U myuser -d myDB -h
>> > myhost -p
>> > 14070
>> > I used this command to extract data:
>> > "C:\Program Files\GDAL\gdal_translate" -a_nodata "-32767" -of GTIFF
>> > "PG:host=myhost port=14070 dbname='myDB' user='myuser'
>> > password='mypassword' schema='dbelange' table='elevationTest' mode=2
>> > where=\"filename LIKE \'%056n05%\'\" " 056N05_testGDAL1.9.tif
>> > Like I said it’s working very well with gdal 1.8
>> > I can send you the 2 files If you want to try on your side.
>> > Do you have another idea?
>> > David
>> > > Date: Sat, 19 May 2012 13:55:47 -0400
>> > > Hi David,
>> > > Do you have a "rid" column in your table with unique values?
>> > > Pierre
>> > > > Sent: Thursday, May 17, 2012 8:13 PM
>> > > > Subject: [postgis-users] PostGis Raster and GDAL 1.9
>> > > > Hi,
>> > > > I stored DEM raster data in PostGIS 2.0 and I used gdal_translate
>> > > > (with
>> > mode=2)
>> > > > to extract a mosaic of tiles. When I’m using GDAL 1.8 is working but
>> > > > when
>> > I’m
>> > > > using GDAL 1.9 I can see the values of pixel for just one tile. For
>> > > > example I
>> > > > uploaded in the database a tile with an attribute filename=056n05_w
>> > > > and an
>> > > > other tile with an filename=056n05_e and I executed the command with
>> > GDAL
>> > > > 1.8 and GDAL 1.9:
>> > > > gdal_translate" -a_nodata "-32767" -of GTIFF "PG:host=myhost
>> > > > port=14070
>> > > > dbname='mybd' user='myuser' password='mypassword'
>> > > > schema='myschema'table='Elevation' mode=2 where=\"filename LIKE
>> > > > \'%056n05%\'\" " 056N05.tif
>> > > > With GDAL 1.8 I obtained a mosaic of 2 tiles (the result expected)
>> > > > but with
>> > GDAL
>> > > > 1.9, I obtained a raster with the same extent but only the values of
>> > > > the tile
>> > > > 056n05_w are present. The pixels of the tile 056n05_w have a value
>> > > > 0.
>> > > > I tried the stable version 1.9 MSVC2008 (Win32) and development
>> > > > version
>> > > > available today at http://www.gisinternals.com/sdk/
>> > <https://email.nrcan.gc.ca/owa/redir.aspx?C=OzXx4wlk90m3TV7W8fzG7_FxObj
>> > PB88I1bAwXOtZColSmDyhIvj_1yhbCVJUJ0vrnCWWTuivB9Y.&URL=http://www.g
>> > > > isinternals.com/sdk/> and I have still the same problem. For your
>> > information,
>> > > > I'm running GDAL on windows7 and PostGIS 2.0 is installed on a Linux
>> > > > server.
>> > I
>> > > > tried many version of GDAL 1.9 and I always have the same problem.
>> > > > The
>> > version
>> > > > 1.8 is working very well but I would like to take advantage of the
>> > improvements
>> > > > in the last version because I'm working on a project where
>> > > > processing time is
>> > > > very important.
>> > > > Does anybody have any idea about this problem ?
>> > > > Thanks
>> > > > David Bélanger
>> > > _______________________________________________
>> > > postgis-users mailing list
>> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
Jorge Arevalo
http://www.libregis.org
