[postgis-users] PostGis Raster and GDAL 1.9
David B�langer
belanger_david at live.ca
Thu May 31 17:54:37 PDT 2012
Hi Jorge,
Did you receive my email with the files requested? I used an other adresse to send you the files.
David
> From: jorgearevalo at libregis.org
> Date: Mon, 28 May 2012 10:07:09 +0200
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] PostGis Raster and GDAL 1.9
> Hi,
> David, could you please attach the original files? Seems to be a
> problem with the way the driver gets the origin of the raster
> coverage, yes.
> The code in GDAL trunk is under development. Slowness problem is one
> of the reasons.
> Best regards,
> Jorge
> On Tue, May 22, 2012 at 7:01 PM, David B�langer <belanger_david at live.ca> wrote:
> > Hi,
> > I did tests and all gave the result expected. It seem to be a problem with
> > the origin of the result file (see attached file). The application has taken
> > the origin of the file 056n05_0100_deme.tif instead of the origin of the
> > file 056n05_0100_demw.tif. What do you think ?
> > For your information the files are in geographic coordinate system.
> > David
> >> From: Pierre.Racine at sbf.ulaval.ca
> >> Date: Tue, 22 May 2012 11:37:03 -0400
> >> I would maybe do some tests:
> >> 1) Remove the -a_nodata "-32767" parameter. Why did you have to set it? Is
> >> the nodata set properly in PostGIS for all rows?
> >> 2) Extract one file at a time with mode=2 and then with mode=1
> >> Pierre
> >> > -----Original Message-----
> >> > From: postgis-users-bounces at postgis.refractions.net
> >> > [mailto:postgis-users-
> >> > bounces at postgis.refractions.net] On Behalf Of David B?langer
> >> > Sent: Tuesday, May 22, 2012 10:25 AM
> >> > Hi Pierre,
> >> > Yes I have a unique rid (Integer) with sequential number. I used the
> >> > tool
> >> > raster2pgsql.exe to upload the data in the database. I uploaded 2 files
> >> > "C:\Program Files\PostgreSQL\9.1\bin\raster2pgsql.exe" -I -e -Y -F -s
> >> > 4269
> >> > e:\dir\*.tif dbelange.elevationTest | "psql.exe" -U myuser -d myDB -h
> >> > myhost -p
> >> > 14070
> >> > I used this command to extract data:
> >> > "C:\Program Files\GDAL\gdal_translate" -a_nodata "-32767" -of GTIFF
> >> > "PG:host=myhost port=14070 dbname='myDB' user='myuser'
> >> > password='mypassword' schema='dbelange' table='elevationTest' mode=2
> >> > where=\"filename LIKE \'%056n05%\'\" " 056N05_testGDAL1.9.tif
> >> > Like I said it’s working very well with gdal 1.8
> >> > I can send you the 2 files If you want to try on your side.
> >> > Do you have another idea?
> >> > David
> >> > > Date: Sat, 19 May 2012 13:55:47 -0400
> >> > > Hi David,
> >> > > Do you have a "rid" column in your table with unique values?
> >> > > Pierre
> >> > > > Sent: Thursday, May 17, 2012 8:13 PM
> >> > > > Subject: [postgis-users] PostGis Raster and GDAL 1.9
> >> > > > Hi,
> >> > > > I stored DEM raster data in PostGIS 2.0 and I used gdal_translate
> >> > > > (with
> >> > mode=2)
> >> > > > to extract a mosaic of tiles. When I’m using GDAL 1.8 is working but
> >> > > > when
> >> > I’m
> >> > > > using GDAL 1.9 I can see the values of pixel for just one tile. For
> >> > > > example I
> >> > > > uploaded in the database a tile with an attribute filename=056n05_w
> >> > > > and an
> >> > > > other tile with an filename=056n05_e and I executed the command with
> >> > GDAL
> >> > > > 1.8 and GDAL 1.9:
> >> > > > gdal_translate" -a_nodata "-32767" -of GTIFF "PG:host=myhost
> >> > > > port=14070
> >> > > > dbname='mybd' user='myuser' password='mypassword'
> >> > > > schema='myschema'table='Elevation' mode=2 where=\"filename LIKE
> >> > > > \'%056n05%\'\" " 056N05.tif
> >> > > > With GDAL 1.8 I obtained a mosaic of 2 tiles (the result expected)
> >> > > > but with
> >> > GDAL
> >> > > > 1.9, I obtained a raster with the same extent but only the values of
> >> > > > the tile
> >> > > > 056n05_w are present. The pixels of the tile 056n05_w have a value
> >> > > > 0.
> >> > > > I tried the stable version 1.9 MSVC2008 (Win32) and development
> >> > > > version
> >> > > > available today at http://www.gisinternals.com/sdk/
> >> > <https://email.nrcan.gc.ca/owa/redir.aspx?C=OzXx4wlk90m3TV7W8fzG7_FxObj
> >> > PB88I1bAwXOtZColSmDyhIvj_1yhbCVJUJ0vrnCWWTuivB9Y.&URL=http://www.g
> >> > > > isinternals.com/sdk/> and I have still the same problem. For your
> >> > information,
> >> > > > I'm running GDAL on windows7 and PostGIS 2.0 is installed on a Linux
> >> > > > server.
> >> > I
> >> > > > tried many version of GDAL 1.9 and I always have the same problem.
> >> > > > The
> >> > version
> >> > > > 1.8 is working very well but I would like to take advantage of the
> >> > improvements
> >> > > > in the last version because I'm working on a project where
> >> > > > processing time is
> >> > > > very important.
> >> > > > Does anybody have any idea about this problem ?
> >> > > > Thanks
> >> > > > David Bélanger
> >> > > _______________________________________________
> >> > > postgis-users mailing list
> >> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Jorge Arevalo
> http://www.libregis.org
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120531/6c6c25e6/attachment.html>
