[postgis-users] Getting error that "$libdir/postgis-2.0" cannot be found. Need help with a fix!
Sandro Santilli
strk at keybit.net
Tue May 29 23:09:11 PDT 2012
On Tue, May 29, 2012 at 10:03:10PM -0400, Alex Irlik wrote:
> Hey guys,
> I started getting this error today when I try to select from a column that
> holds a geometry value
> ERROR: could not access file "$libdir/postgis-2.0"
> My selects have been working fine before, but this just started happening
> today. Any tips on how to fix this? I have been keeping my linux server
> up-to-date if that effects anything. I did not change the postgresql or
> postgis settings or files in any way recently, except for updates if there
> were any.
Check the postgresql logs for more info.
If you can, also check the logs of your package manager to see what
it did (ie: what does "kept up-to-date" really means).
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
