[postgis-users] raster2pgsql quoted string error
Bborie Park
bkpark at ucdavis.edu
Thu Nov 1 12:32:07 PDT 2012
Hey Jean-Daniel,
Running the command on landsat.tif with the following resulted in no errors.
raster2pgsql -f elev -F -t 100x100 landsat.tif QC_SRTM > InsertSRTM.sql
So, the raster is fine. I'm wondering if the raster2pgsql is correct
(or the install is corrupt). You may need to reinstall PostGIS.
-bborie
On 11/01/2012 12:23 PM, Jean-Daniel Sylvain wrote:
> Hi bborie
> I would prefer to share my computer with you (;)).
> Seriously, I don't think the problem is with the raster. We imported the same
> image in an other postgis database (version 2.0) without any problem. I try to
> import several others images with my raster2pgsql and we still have the same result.
> I will share you a link where you will find the image with Ubuntu one. It should
> be down there.
> Hope I won't have to re-install all my gear.
> If it's not okay, I will send you the image via email.
> Jean-Daniel
> J'ai lié 1 fichier à ce courriel :
> landsat.tif <http://ubuntuone.com/0ZJgHJwOf2GBW7n8KsnBbO>(54.3 Mo)Ubuntu One
> <https://one.ubuntu.com/referrals/referee/2149434/?next=/>http://ubuntuone.com/0ZJgHJwOf2GBW7n8KsnBbO
> Mozilla Thunderbird <http://www.getthunderbird.com> permet de partager
> facilement des fichiers volumineux par courriel.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
