[postgis-users] the_geom is empty
islanis at infomed.sld.cu islanis at infomed.sld.cu
Tue Nov 6 12:15:57 PST 2012
Hi people, i mounted a shapefile and in the geoserver side dont show
the map and it says "error: geometry contains non-closed rings" and i
found that there is a row in the table of the mounted shapefile that
has no data in the_geom column, how would i get this solved, thanks
This message was sent using IMP, the Internet Messaging Program.
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
Infomed: http://www.sld.cu/
