[postgis-users] the_geom is empty
Francois Hugues hugues.francois at irstea.fr
Wed Nov 7 00:40:10 PST 2012
Sometimes, the geometry column does not show anything but that does not necessarily means it is empty.
Did you try a simple request like select st_isclosed(the_geom) from yourtable or try to load your geometries with openjump.
Hugues.
-------- Message d'origine--------
De: postgis-users-bounces at lists.osgeo.org de la part de islanis at infomed.sld.cu
Date: mar. 06/11/2012 21:15
À: PostGIS Users Discussion
Objet : [postgis-users] the_geom is empty
Hi people, i mounted a shapefile and in the geoserver side dont show
the map and it says "error: geometry contains non-closed rings" and i
found that there is a row in the table of the mounted shapefile that
has no data in the_geom column, how would i get this solved, thanks
This message was sent using IMP, the Internet Messaging Program.
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
Infomed: http://www.sld.cu/
postgis-users mailing list
postgis-users at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121107/ff27bf8f/attachment.bin>
