[postgis-users] the_geom is empty
Matej Mailing
mailing at tam.si
Wed Nov 7 03:30:37 PST 2012
I was always wondering - why does it happen that the geometry column
looks like it's empty but it's not?
Regards,
Matej
2012/11/7 Francois Hugues <hugues.francois at irstea.fr>:
> Sometimes, the geometry column does not show anything but that does not necessarily means it is empty.
> Did you try a simple request like select st_isclosed(the_geom) from yourtable or try to load your geometries with openjump.
> Hugues.
> -------- Message d'origine--------
> De: postgis-users-bounces at lists.osgeo.org de la part de islanis at infomed.sld.cu
> Date: mar. 06/11/2012 21:15
> À: PostGIS Users Discussion
> Objet : [postgis-users] the_geom is empty
> Hi people, i mounted a shapefile and in the geoserver side dont show
> the map and it says "error: geometry contains non-closed rings" and i
> found that there is a row in the table of the mounted shapefile that
> has no data in the_geom column, how would i get this solved, thanks
> This message was sent using IMP, the Internet Messaging Program.
> Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
> Infomed: http://www.sld.cu/
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
