[postgis-users] the_geom is empty
Nicolas Ribot
nicolas.ribot at gmail.com
Wed Nov 7 05:38:22 PST 2012
In PgAdmin, you mean ?
The display grid has a limited size.
Nicolas
On 7 November 2012 12:30, Matej Mailing <mailing at tam.si> wrote:
> Hi,
> I was always wondering - why does it happen that the geometry column
> looks like it's empty but it's not?
> Regards,
> Matej
> 2012/11/7 Francois Hugues <hugues.francois at irstea.fr>:
> > Sometimes, the geometry column does not show anything but that does not
> necessarily means it is empty.
> > Did you try a simple request like select st_isclosed(the_geom) from
> yourtable or try to load your geometries with openjump.
> > Hugues.
> > -------- Message d'origine--------
> > De: postgis-users-bounces at lists.osgeo.org de la part de
> islanis at infomed.sld.cu
> > Date: mar. 06/11/2012 21:15
> > À: PostGIS Users Discussion
> > Objet : [postgis-users] the_geom is empty
> > Hi people, i mounted a shapefile and in the geoserver side dont show
> > the map and it says "error: geometry contains non-closed rings" and i
> > found that there is a row in the table of the mounted shapefile that
> > has no data in the_geom column, how would i get this solved, thanks
> > This message was sent using IMP, the Internet Messaging Program.
> > Este mensaje le ha llegado mediante el servicio de correo electronico
> que ofrece Infomed para respaldar el cumplimiento de las misiones del
> Sistema Nacional de Salud. La persona que envia este correo asume el
> compromiso de usar el servicio a tales fines y cumplir con las regulaciones
> establecidas
> > Infomed: http://www.sld.cu/
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121107/223835f8/attachment.html>
