[postgis-users] FYI: Solution to Using PostGIS in ArcGIS.
Francois Hugues hugues.francois at irstea.fr
Wed Nov 7 01:24:04 PST 2012
Sorry for the copy / paste from french... Here is the translation :
To connect to postgis database you must copy libraries from padmin client to the bien folder where you installed arcgis (for example C:\Program Files\ArcGIS\Desktop10.1\bin) :
·libeay32.dll, libiconv-2.dll, libintl-8.dll, libpq.dll, and ssleay32.dll pour votre windows 32 bits
·libeay32.dll, libintl.dll, libpq.dll, and ssleay32.dll  pour votre windows 64 bits
Hugues.
-------- Message d'origine--------
De: postgis-users-bounces at lists.osgeo.org de la part de Francois Hugues
Date: mer. 07/11/2012 10:21
À: PostGIS Users Discussion
Objet : Re: [postgis-users] FYI: Solution to Using PostGIS in ArcGIS.
Some tips to connect to postgis from arcgis 10 with windows :
Pour une connexion à une base de données PostGIS, il faut copier les librairies dll de votre client de connexion pgadmin dans le répertoire bin de votre installation arcgis (ex C:\Program Files\ArcGIS\Desktop10.1\bin.
Hugues.
De: postgis-users-bounces at lists.osgeo.org de la part de Paolo Corti
Date: mer. 07/11/2012 09:25
À: Robert Buckley; PostGIS Users Discussion
On Wed, Nov 7, 2012 at 7:39 AM, Robert Buckley <robertdbuckley at yahoo.com> wrote:
> Hi,
> just my 2Cents..ArcGIS is now realising that there is a great need for
> FOSSGIS interfaces within the ESRI Architecture. If you have ArcSDE and
> ArcEditor (only a few 10s of thousands) you can work with PostgreSQL and
> PostGIS dbs.
> Other than that, there may be some opensource plugins or extentions that you
> may be able to test.
> http://gis.stackexchange.com/questions/147/how-can-i-connect-to-a-postgis-database-from-arcmap-9-3-and-10-0
> http://www.paolocorti.net/2008/06/06/spatial-database-for-postgres-and-arcgis-users-how-to-choose/
Hello Robert
please be aware that zigGIS was discontinued (the posted links are
very old) [1].
In any case, the source code has always been around [2] and I think it
should be quiete easy to adapt it to work to latest ArcGIS versions.
regards
p
[1] https://groups.google.com/forum/?fromgroups=#!topic/ziggis/FK6KNRVk3p4
[2] http://code.google.com/p/ziggis/
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
postgis-users mailing list
postgis-users at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121107/0cb574b8/attachment.bin>
