[postgis-users] Is it possible to import shapefile from PL/PGSQL or using SQL command?
GregoryKramdia algomorph at gmail.com
Tue Nov 13 12:20:47 PST 2012
Does anyone know of any way PostGIS can import a shapefile directly by
running an SQL statement (i.e. is there any function identical to shp2pgsql
that PostGIS defines in SQL during installation?)
Thanks in advance
View this message in context: http://postgis.17.n6.nabble.com/Is-it-possible-to-import-shapefile-from-PL-PGSQL-or-using-SQL-command-tp5001170.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
