[postgis-users] Is it possible to import shapefile from PL/PGSQL or using SQL command?
Stephen Woodbridge woodbri at swoodbridge.com
Tue Nov 13 12:32:46 PST 2012
On 11/13/2012 3:20 PM, GregoryKramdia wrote:
> Does anyone know of any way PostGIS can import a shapefile directly by
> running an SQL statement (i.e. is there any function identical to shp2pgsql
> that PostGIS defines in SQL during installation?)
No, don't think there is anything close to that. If you are handy with a
little C code you might be able to write a stored procedure in C that
mimics shp2pgsql and would be callable from SQL, but I'm not sure why
you would want to do this.
-Steve
