[postgis-users] Is it possible to import shapefile from PL/PGSQL or using SQL command?
GregoryKramdia
algomorph at gmail.com
Tue Nov 13 13:20:05 PST 2012
Thanks, Steve.
It's true, I could just export the C code for shp2pgsql into a dll and
define the function in PostgreSQL.
We need a utility that would be able to ingest a set of files arriving at
the host into a set of tables, process them, and add the data into existing
tables. It so happens that one of the files is a shapefile. For now, I've
decided to go around this by using some shp-reading library within the
client application.
View this message in context: http://postgis.17.n6.nabble.com/Is-it-possible-to-import-shapefile-from-PL-PGSQL-or-using-SQL-command-tp5001170p5001172.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
