[postgis-users] Importing data in Lambert72 (Belgium)
Jo winfixit at gmail.com
Tue Nov 13 16:36:21 PST 2012
Hi Nicolas and Paolo,
This is what I have been able to come up with:
DROP EXTENSION postgis;
CREATE EXTENSION postgis;
DROP TABLE IF EXISTS stops;
CREATE TABLE stops
  stopid bigint NOT NULL,
  stopidentifier bigint,
  description text,
  street text,
  municipality text,
  parentmunicipality text,
  lat double precision,
  lon double precision,
  stopisaccessible boolean,
  stopispublic boolean,
  PRIMARY KEY (stopid)
WITH (
  OIDS=FALSE
ALTER TABLE stops
  OWNER TO postgres;
CREATE OR REPLACE FUNCTION addwgs84() RETURNS trigger AS
  $body$
  DECLARE
    node geometry;
  BEGIN
    node := st_transform(st_setSRID(st_makePoint(NEW.lat, NEW.lon),
31370),4326);
    NEW.lat := st_x(node);
    NEW.lon := st_y(node);
    RETURN NEW;
  END;
  $body$
  LANGUAGE 'plpgsql';
CREATE TRIGGER wgs84
  AFTER INSERT OR UPDATE ON stops
  FOR EACH ROW EXECUTE PROCEDURE addwgs84();
COPY stops FROM 'C:/stops.csv' DELIMITERS ';' CSV HEADER;
Unfortunately, this doesn't result in WGS84 lat and lon, but gives me
lambert72 once again. I must be missing something crucial somewhere. I
don't need the geometry in the table, so I took it out again. I'm not going
to use it to calculate distances. This is only an intermediate step in
converting all of it to an XML-format suitable for Openstreetmap.org.
Thanks for your help. Hopefully I'm near to the goal I wanted to reach, now
and you can nudge me a bit further in the right direction.
Jo
2012/11/13 Nicolas Ribot <nicolas.ribot at gmail.com>
> Hi,
> Use the  COPY command to load CSV to a table.
> The rest depends if you want to display/use the geometry, or you're only
> interested in the coordinates:
> • Add a geometry column
> • st_makePoint to build a point from coordinates
> • A trigger to create the WGS84 point from coordinates with st_transform:
> st_transform(st_setSRID(st_makePoint(coordinateX, coordinateY), 31300),
> 4326)
> Nicolas
> On 13 November 2012 13:54, Jo <winfixit at gmail.com> wrote:
>> Hi,
>> I've been reading docs, but I'm afraid I can't figure it out on my own.
>> I have a csv-file:
>> POI_ID;POI_name;coordinateX;coordinateY
>> Where X and Y are in Lambert72.
>> How can I get these in a table that includes 2 columns with those same
>> coordinates in WGS84? Should I have a column with a geometry type and
>> a point in it? Can I create a trigger function which updates the WGS84
>> as the Lambert72 are inserted?
>> Jo
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121114/7fec8672/attachment.html>
