[postgis-users] Update to Postgis 2.0
Dmitriy Tyugaev dtyugaev at gmail.com
Mon Nov 26 05:46:40 PST 2012
abbr_RF is a table with acronyms, nothing special.
The base is also the most common. It's not a hybrid with SDE or something
like that.
I have successfully restored this dump into the base with Postgis 1.5
Any ideas?
On Mon, Nov 26, 2012 at 4:10 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Mon, Nov 26, 2012 at 02:03:51PM +0400, Dmitriy Tyugaev wrote:
> > Thanks for the reply!
> > Yes, I restore in the Postgis database. Install using the command "CREATE
> > EXTENSION postgis;"
> > Logs of execution your command in the attachment. I don't see any serious
> > errors.
> Thanks, st_area(geography) and st_length(geography) now added to the skip
> list.
> As for the rest of the messages they really look unrelated to postgis.
> I mean:
> > ERROR:  relation "abbr_RF" already exists
> That's your own schema, right ?
> Did you create more objects than only PostGIS in the target DB before
> restoring the dump ?
> --strk;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121126/8e3c3ce0/attachment.html>
