[postgis-users] Why PostGIS ST_Intersection much slower than ArcGIS Intersect ?
Étienne Desgagné
etienne.desgagne at roche.ca
Thu Nov 29 08:04:57 PST 2012
It take millisecond to me to when using ST_Intersects on a spatial join.
What take much longer is when using ST_Intersection in the SELECT clause to
effectively clip a layer with the other one
My computer run under Windows 7 64bits with dual core 2.70GHZ and 8 Go RAM.
Is there anything I can do to check if its normal behavior on this platform
or if something may be wrong on my installation?
Thanks
Etienne
De : postgis-users-bounces at lists.osgeo.org
[mailto:postgis-users-bounces at lists.osgeo.org] De la part de Jeff Lake
Envoyé : 29 novembre 2012 09:15
À : postgis-users at lists.osgeo.org
Objet : Re: [postgis-users] Why PostGIS ST_Intersection much slower than
ArcGIS Intersect ?
Must have something to do with windows and or memory ..
I use ST_Intersects daily on a Linux Server (PostGIS 2.0, PG 9.1.6) with a
quad core Xeon and 16gb memory
it takes milliseconds on much larger layers ..
Jeff Lake
MichiganWxSystem <http://www.michiganwxsystem.com>
AllisonHouse <http://www.allisonhouse.com>
GRLevelXStuff <http://www.grlevelxstuff.com>
On 11/28/2012 16:22, Étienne Desgagné wrote:
Hello,
I don't want to denigrate PostGIS in any way and I know that my
comparison may be wrong but I'm trying to understand why a basic
ST_Intersection of two relatively small layers (< 1000 polygons) take about
1m40 sec in PostGIS(2.0 on PG 9.2 on Windows) while applying the ArcGIS
Intersect on same layers and machine take about 2 sec?
I'm aware of some PostgreSQL tuning settings but even applying basic tuning
recommendation for PostGIS I'm facing the same problem...
My two layers also have a spatial index.
Is it normal behavior? Any suggestion for reaching better performance?
Note that I'm also using ST_Intersects on the join to filter only
intersecting features...
Thanks a lot
Etienne
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121129/50a0d447/attachment.html>
