[postgis-users] Topology Postgis 2.0
ps.tiara ps.tiara at yahoo.com
Thu Oct 4 07:11:47 PDT 2012
Hi, it's me again..
I have installed Postgis 2.0.1 and the function of toTopoGeom has worked...
I used toTopogeom for multilinestring (2d & 3d)  geometry and it worked..
It also worked for  polygon 3d geometry...but it didn't work for
multipolygon 3d..
Here is the message error :
update public.phtomulti_srid
set topo = topology.toTopoGeom(geom,'phtomulti_topo',1,0.0000001)
where id='1';
ERROR:  Column has Z dimension but geometry does not
CONTEXT:  SQL statement "INSERT INTO phtomulti_topo.node(node_id, geom)
    VALUES(26,'0101000020E61000000000000000000000000000000000F03F')"
PL/pgSQL function "st_modedgesplit" line 81 at EXECUTE statement
PL/pgSQL function "topogeo_addpoint" line 91 at assignment
PL/pgSQL function "topogeo_addlinestring" line 140 at assignment
SQL statement "SELECT array_cat(edges, array_agg(x)) FROM ( select
topology.TopoGeo_addLinestring(atopology, rec.geom, tol) as x ) as foo"
PL/pgSQL function "topogeo_addpolygon" line 27 at assignment
PL/pgSQL function "totopogeom" line 100 at FOR over SELECT rows
It didn't work with any tolerance...
Is this the limitation of topology Postgis 2.0.1?
Thank you...
View this message in context: http://postgis.17.n6.nabble.com/Topology-Postgis-2-0-tp5000006p5000216.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
