[postgis-users] st_closespoint weridness
Dave Potts
dave.potts at pinan.co.uk
Fri Oct 5 15:07:47 PDT 2012
Martin Davis wrote:
> If the point is inside the polygon, the distance between them is 0.
Hmm I do not understand, then nearest point should be along the boundary
of the polygon.
> Can't get closer than that!
> You may want to try ST_ClosestPoint(ST_Boundary(poly), point)
This worked, many thanks
Dave.
> On 10/5/2012 12:10 PM, Dave Potts wrote:
>> just tried a
>> select st_closestpoint(poly,point) and got the result point
>> The point is within a the closed polygon poly, the version is postgis
>> 2.0
>> is there any sane reason why this behave in this manner. I had expected
>> to the value of the x/y coordinate pair from the polylgon that is
>> nearest
>> to point, not the value of point!
>> Any suggestions as what I might be doing wrong? or an suggestions for a
>> better way of doing this?
>> regards
>> Dave.
> postgis-users mailing list
