[postgis-users] Loading triangles
Nicolas Ribot
nicolas.ribot at gmail.com
Mon Oct 8 09:18:02 PDT 2012
Don't forget to add the first point at the end of the polygon
definition (required by OGC specs).
in your example, the last point (0 0 -2) is different from the first
one (0 0 -1)
I understood triangle data would be in the database, in the form of
column values, thus the makeline approach.
Nicolas
On 8 October 2012 16:39, Ed Linde <edolinde at gmail.com> wrote:
> Thanks Nicolas, what about something like
> ST_GeomFromText('POLYGON((0 0 -1,2 0 -2,1 2 -1 ,0 0 -2))')
> would that work?
> On Mon, Oct 8, 2012 at 4:34 PM, Nicolas Ribot <nicolas.ribot at gmail.com>
> wrote:
>> Hi,
>> You could create triangles by calling st_makeLine and st_makePolygon:
>> select st_makePolygon(st_makeLine('{point1, point2, point3, point1}'))
>> from triangles
>> (the 4 points are put in a array before calling makeLine).
>> Yes for the Gist index on the column.
>> Nicolas
>> On 8 October 2012 16:03, Ed Linde <edolinde at gmail.com> wrote:
>> > Hi All,
>> > I am looking at an easy way to load a lot of triangles into a geometry
>> > column. Wondering what is the best way to
>> > create a triangle when I have 3 points? Is there a function I can use?
>> > Also can I just index this column with Gist and then query against a box
>> > I
>> > make to see what triangles intersect
>> > with this rectangle?
>> > Cheers,
>> > Ed
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
