[postgis-users] Geocoding using www_fdw and Google APIs
Jeremy
jeremy001 at gmail.com
Mon Oct 8 22:15:28 PDT 2012
Hi all,
I've got a question on how to define a server & foreign table to pull
back latitude and longitude from a street address. I've been working
from examples like twitter or google searches - all of which return a
fairly flat data structure. The structure of the geocode return is
quite different, however. For instance, it contains a field 'geometry'
which in turn contains a field 'location' which finally contains
values for 'lat' and 'long'.
The only information I'm interested in is the geometry:location:lat,
geometry:location:long and the geometry:locaiton_type
I'm not sure how to structure the fields in the foreign table
www_fdw_google_geocode so that this will work. Any advice would be
greatly appreciated. Please see end of message for code, command and
sample xml response.
Thanks in advance,
Jeremy.
-Code I have so far----------------------------------------------
DROP EXTENSION IF EXISTS www_fdw CASCADE;
CREATE EXTENSION www_fdw;
CREATE SERVER www_fdw_server_google_geocode FOREIGN DATA WRAPPER www_fdw
OPTIONS (uri 'http://maps.google.com/maps/api/geocode/xml');
CREATE USER MAPPING FOR current_user SERVER www_fdw_server_google_geocode;
CREATE FOREIGN TABLE www_fdw_google_geocode (
/* parameters used in request */
sensor text,
address text,
/* fields in response */
/* NOT SURE HOW TO STRUCTURE THIS PART OF THE TABLE */
/* The response data is not flat. Please see sample data at end */
) SERVER www_fdw_server_google_geocode;
-/Code I have so far----------------------------------------------
-Command I intend to use------------------------------------------
postgres=# SELECT latitude, longitude, location_type from
www_fdw_google_geocode where sensor='false' AND address='2 Some
street, somewhere, somewhereville' LIMIT 1;
-/Command I intend to use-----------------------------------------
-Sample response from geocoding web service----------------------
<GeocodeResponse>
<status>OK</status>
<result>
<type>street_address</type>
<formatted_address>2 Southbank Blvd, Southbank VIC 3006,
Australia</formatted_address>
<address_component>
<long_name>2</long_name>
<short_name>2</short_name>
<type>street_number</type>
</address_component>
<address_component>
<long_name>Southbank Blvd</long_name>
<short_name>Southbank Blvd</short_name>
<type>route</type>
<address_component>
<long_name>Southbank</long_name>
<short_name>Southbank</short_name>
<type>locality</type>
<type>political</type>
<address_component>
<long_name>Victoria</long_name>
<short_name>VIC</short_name>
<type>administrative_area_level_1</type>
<address_component>
<long_name>Australia</long_name>
<short_name>AU</short_name>
<type>country</type>
<address_component>
<long_name>3006</long_name>
<short_name>3006</short_name>
<type>postal_code</type>
<geometry>
<location>
<lat>-37.8224465</lat>
<lng>144.9630868</lng>
</location>
<location_type>ROOFTOP</location_type>
<viewport>
<southwest>
<lat>-37.8237955</lat>
<lng>144.9617378</lng>
</southwest>
<northeast>
<lat>-37.8210975</lat>
<lng>144.9644358</lng>
</northeast>
</viewport>
</geometry>
<partial_match>true</partial_match>
</result>
[possibly more results after the first - we only want the first one]
</GeocodeResponse>
-/Sample response from geocoding web service---------------------
