[postgis-users] Select polygons within polygon with PostGIS 2.0
Michal Zimmermann
zimmicz at gmail.com
Thu Oct 11 00:30:30 PDT 2012
No, if I try select * from spatial_ref_sys where srid=4326, I get
exactly one result. The topology table belongs to topology scheme,
while the spatial_ref_sys belongs to public scheme, could that be a
problem?
On 10/11/12, Sandro Santilli <strk at keybit.net> wrote:
> On Thu, Oct 11, 2012 at 09:02:58AM +0200, Michal Zimmermann wrote:
>> Hi,
>> I tried with SELECT CreateTopology('kraje_topo', 4326); and got the
>> following error: ERROR: AddGeometryColumn() - invalid SRID. Is there
>> something special I need to do before creating topology?
> The SRID must be in spatial_ref_sys.
> Did you forget to load spatial_ref_sys.sql ?
> --strk;
> http://www.cartodb.com - Map, analyze and build applications with your
> data
> ~~ http://strk.keybit.net
> postgis-users mailing list
Michal Zimmermann (zimmi)
WWW: http://www.zimmi.cz
