[postgis-users] Not what I was expecting....
Jeff Lake
jeff at michiganwxsystem.com
Fri Oct 12 13:15:44 PDT 2012
Thank you Paul ..
getting the correct projection (SRID) on the table made
this possible
http://www.michiganwxsystem.com/wxweb.php?run=pass&temp=warningmap2&state=son
the map is 'clickable' using postGIS to find the EC Area's based off the
X,Y from your click
*Jeff Lake*
MichiganWxSystem <http://www.michiganwxsystem.com>
AllisonHouse <http://www.allisonhouse.com>
GRLevelXStuff <http://www.grlevelxstuff.com>
On 10/11/2012 20:56, Paul Ramsey wrote:
> Find the .prj file next to your .shp file and plug it into here
> http://prj2epsg.org/search
> P
> On Thu, Oct 11, 2012 at 4:38 PM, Jeff Lake <jeff at michiganwxsystem.com> wrote:
>> I obtained a shape file from Environment Canada,
>> imported it into a postGIS enabled database with shp2pgsql with no problem.
>> queried the table and noticed the SRID was -1, reset it with
>> UpdateGeometrySRID to 4326
>> now when query the table I get the following
>> (had the same results before updating the SRID)
>> SELECT ST_AsText(the_geom) FROM canada WHERE name LIKE 'Caledon'
>> MULTIPOLYGON(((7185795.71819089 960058.015757074,7186925.78661135
>> 958323.504835823,7187144.84742271 >>>>>>>> continues on
>> I was expecting Lat/Long
>> I *think* this is meter's ??
>> anybody care to guess ??
>> and if what needs to be adjusted and where
>> Jeff Lake
>> MichiganWxSystem
>> AllisonHouse
>> GRLevelXStuff
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121012/e9b62b06/attachment.html>
