[postgis-users] PostGIS 2 RPM
Bborie Park bkpark at ucdavis.edu
Thu Oct 18 07:24:34 PDT 2012
It looks like the linker can't find libpq.  You'll want to add the
following to /etc/ld.so.conf.
/usr/pgsql-9.1/lib
-bborie
On Thu, Oct 18, 2012 at 6:09 AM, Jeff Lake <jeff at michiganwxsystem.com> wrote:
> Is there any reasoning why EL5 does not have a postGIS2_91 RPM ??
> this is on CentOS 5.8 64bit
> I have tried numerous times to install from source and keep getting raster
> error
> configure params
> ./configure --with-raster --with-pgconfig=/usr/pgsql-9.1/bin/pg_config
> --with-geosconfig=/geos-3.3.5/tools/geos-config
>   PostGIS is now configured for x86_64-unknown-linux-gnu
>  -------------- Compiler Info -------------
>   C compiler:           gcc -g -O2
>   C++ compiler:         g++ -g -O2
>   SQL preprocessor:     /usr/bin/cpp -traditional-cpp -P
>  -------------- Dependencies --------------
>   GEOS config:          /geos-3.3.5/tools/geos-config
>   GEOS version:         3.3.5
>   GDAL config:          /usr/local/bin/gdal-config
>   GDAL version:         1.9.1
>   PostgreSQL config:    /usr/pgsql-9.1/bin/pg_config
>   PostgreSQL version:   PostgreSQL 9.1.6
>   PROJ4 version:        48
>   Libxml2 config:       /usr/bin/xml2-config
>   Libxml2 version:      2.6.26
>   JSON-C support:       no
>   PostGIS debug level:  0
>   Perl:                 /usr/bin/perl
>  --------------- Extensions ---------------
>   PostGIS Raster:       enabled
>   PostGIS Topology:     enabled
>  -------- Documentation Generation --------
>   xsltproc:             /usr/bin/xsltproc
>   xsl style sheets:
>   dblatex:
>   convert:              /usr/bin/convert
>   mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
> Entering directory `/postgis-2.0.1/raster/loader'
> /bin/sh ../../libtool --mode=link gcc -g -O2  -fPIC -DPIC  -Wall
> -Wmissing-prototypes -I../rt_core -I../../liblwgeom  -I/usr/local/include
> -I/usr/local/include   raster2pgsql.o ../rt_core/librtcore.a
> ../rt_core/librtcore.a ../../liblwgeom/liblwgeom.la -L/usr/local/lib -lgdal
> -L/usr/local/lib -lgeos_c  -lc -lm -o raster2pgsql
> libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
> -I../rt_core -I../../liblwgeom -I/usr/local/include -I/usr/local/include
> raster2pgsql.o -o .libs/raster2pgsql  ../rt_core/librtcore.a
> ../../liblwgeom/.libs/liblwgeom.so -L/usr/local/lib
> /usr/local/lib/libproj.so /usr/local/lib/libgdal.so -L/usr/lib64
> -L/usr/kerberos/lib64 -L/usr/lib64/mysql -lsqlite3 /usr/lib64/libexpat.so
> -lgif -ljpeg -lpng -lpq -lcurl -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err
> -lidn -lz -lmysqlclient -lpthread -lrt -lssl -lcrypto -ldl
> /usr/local/lib/libgeos_c.so /usr/local/lib/libgeos.so -lc -lm -Wl,-rpath
> -Wl,/usr/local/lib -Wl,-rpath -Wl,/usr/lib64
> /usr/bin/ld: cannot find -lpq
> collect2: ld returned 1 exit status
> make[2]: *** [raster2pgsql] Error 1
> make[2]: Leaving directory `/postgis-2.0.1/raster/loader'
> make[1]: *** [rtloader] Error 2
> make[1]: Leaving directory `/postgis-2.0.1/raster'
> make: *** [all] Error 1
> Jeff Lake
> MichiganWxSystem
> AllisonHouse
> GRLevelXStuff
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
