[postgis-users] PostGIS 2 RPM
Jeff Lake
jeff at michiganwxsystem.com
Thu Oct 18 06:09:47 PDT 2012
Is there any reasoning why EL5 does not have a postGIS2_91 RPM ??
this is on CentOS 5.8 64bit
I have tried numerous times to install from source and keep getting
raster error
configure params
./configure --with-raster --with-pgconfig=/usr/pgsql-9.1/bin/pg_config
--with-geosconfig=/geos-3.3.5/tools/geos-config
PostGIS is now configured for x86_64-unknown-linux-gnu
-------------- Compiler Info -------------
C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
SQL preprocessor: /usr/bin/cpp -traditional-cpp -P
-------------- Dependencies --------------
GEOS config: /geos-3.3.5/tools/geos-config
GEOS version: 3.3.5
GDAL config: /usr/local/bin/gdal-config
GDAL version: 1.9.1
PostgreSQL config: /usr/pgsql-9.1/bin/pg_config
PostgreSQL version: PostgreSQL 9.1.6
PROJ4 version: 48
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.6.26
JSON-C support: no
PostGIS debug level: 0
Perl: /usr/bin/perl
--------------- Extensions ---------------
PostGIS Raster: enabled
PostGIS Topology: enabled
-------- Documentation Generation --------
xsltproc: /usr/bin/xsltproc
xsl style sheets:
dblatex:
convert: /usr/bin/convert
mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
Entering directory `/postgis-2.0.1/raster/loader'
/bin/sh ../../libtool --mode=link gcc -g -O2 -fPIC -DPIC -Wall
-Wmissing-prototypes -I../rt_core -I../../liblwgeom -I/usr/local/include
-I/usr/local/include raster2pgsql.o ../rt_core/librtcore.a
../rt_core/librtcore.a ../../liblwgeom/liblwgeom.la -L/usr/local/lib
-lgdal -L/usr/local/lib -lgeos_c -lc -lm -o raster2pgsql
libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
-I../rt_core -I../../liblwgeom -I/usr/local/include -I/usr/local/include
raster2pgsql.o -o .libs/raster2pgsql ../rt_core/librtcore.a
../../liblwgeom/.libs/liblwgeom.so -L/usr/local/lib
/usr/local/lib/libproj.so /usr/local/lib/libgdal.so -L/usr/lib64
-L/usr/kerberos/lib64 -L/usr/lib64/mysql -lsqlite3
/usr/lib64/libexpat.so -lgif -ljpeg -lpng -lpq -lcurl -lgssapi_krb5
-lkrb5 -lk5crypto -lcom_err -lidn -lz -lmysqlclient -lpthread -lrt -lssl
-lcrypto -ldl /usr/local/lib/libgeos_c.so /usr/local/lib/libgeos.so -lc
-lm -Wl,-rpath -Wl,/usr/local/lib -Wl,-rpath -Wl,/usr/lib64
/usr/bin/ld: cannot find -lpq
collect2: ld returned 1 exit status
make[2]: *** [raster2pgsql] Error 1
make[2]: Leaving directory `/postgis-2.0.1/raster/loader'
make[1]: *** [rtloader] Error 2
make[1]: Leaving directory `/postgis-2.0.1/raster'
make: *** [all] Error 1
*Jeff Lake*
MichiganWxSystem <http://www.michiganwxsystem.com>
AllisonHouse <http://www.allisonhouse.com>
GRLevelXStuff <http://www.grlevelxstuff.com>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121018/8ace1f4e/attachment.html>
