[postgis-users] How to make some geometry column visible to Qgis
Pietro Rossin pierigis at gmail.com
Tue Oct 23 08:17:51 PDT 2012
Sandro, According to the chapter 4.3.2 of the postgis 2.0.1 manual (page
31) you're right..
So, I'll use the addgeometrycolumn() function to handle geometry columns,
but..
May be that the technique I used before is a bug in postgis??
Bye
Pietro
2012/10/22 Sandro Santilli [via PostGIS] <
ml-node+s17n5000690h14 at n6.nabble.com>
> On Mon, Oct 22, 2012 at 02:39:31AM -0700, Pietro Rossin wrote:
> > My problem is that the main table (a huge one with mixed geometry data
> > type) has its own geometry column.
> > When qgis starts the connection to this db automatically looks into the
> > geometry column set and find the geom.column relative to the main table,
> so
> > it searches that table for the geometry type and take a lot of time to
> do
> > it...
> > How can I hide this geometry column?
> You can tell QGis to "only look in geometry_columns" (which became
> "only look in layer registries" in current development version).
> It's a configuration of the PostgreSQL connection.
> --strk;
>  http://www.cartodb.com - Map, analyze and build applications with your
> data
>                                        ~~ http://strk.keybit.net
> postgis-users mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5000690&i=0>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://postgis.17.n6.nabble.com/How-to-make-some-geometry-column-visible-to-Qgis-tp5000570p5000690.html
>  To unsubscribe from How to make some geometry column visible to Qgis, click
> here<http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5000570&code=cGllcmlnaXNAZ21haWwuY29tfDUwMDA1NzB8MjMwODY1MTQ5>
> NAML<http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://postgis.17.n6.nabble.com/How-to-make-some-geometry-column-visible-to-Qgis-tp5000570p5000714.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121023/64fd6934/attachment.html>
