[postgis-users] How to make some geometry column visible to Qgis
Sandro Santilli strk at keybit.net
Mon Oct 22 07:28:14 PDT 2012
On Mon, Oct 22, 2012 at 02:39:31AM -0700, Pietro Rossin wrote:
> My problem is that the main table (a huge one with mixed geometry data
> type) has its own geometry column.
> When qgis starts the connection to this db automatically looks into the
> geometry column set and find the geom.column relative to the main table, so
> it searches that table for the geometry type and take a lot of time to do
> it...
> How can I hide this geometry column?
You can tell QGis to "only look in geometry_columns" (which became
"only look in layer registries" in current development version).
It's a configuration of the PostgreSQL connection.
--strk;
 http://www.cartodb.com - Map, analyze and build applications with your data
                                       ~~ http://strk.keybit.net
