[postgis-users] How to make some geometry column visible to Qgis
Pietro Rossin pierigis at gmail.com
Mon Oct 22 03:59:56 PDT 2012
Super!
I didn't realize that the geometry_column view could be edited...
So
I added at the end of the view sql statement:
AND c.relname not like  'entities'
that was converted by the system to
AND c.relname !~~ 'entities'::text
Then in qgis I had to specify that it must look only in geoetry_columns
table and the table entities disappeared!
Thnx very, very much!
Pietro
2012/10/22 Francois Hugues <hugues.francois at irstea.fr>
> Your view is defined by a sql select so you should try to leave this
> select as is except for the where clause where you could add something like
> : and c.relname not like 'your_table_name'
> I tried it with one of my table and this was ok, the table disappeared
> from the geometry_columns view
> Hugues.
> *De :* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *De la part de* Pietro
> Rossin
> *Envoyé :* lundi 22 octobre 2012 11:40
> *À :* postgis-users at postgis.refractions.net
> *Objet :* Re: [postgis-users] How to make some geometry column visible to
> Qgis
> Hello Hugues
> in my database I have both views and a main table on which these views
> pick data from.
> All of them have their own geometry column registered into the geometry
> column set by postgis
> My problem is that the main table (a huge one with mixed geometry data
> type) has its own geometry column.
> When qgis starts the connection to this db automatically looks into the
> geometry column set and find the geom.column relative to the main table, so
> it searches that table for the geometry type and take a lot of time to do
> it...
> How can I hide this geometry column?
> Thnx
> Pietro
> 2012/10/22 Francois Hugues [via PostGIS] <[hidden email]<http://user/SendEmail.jtp?type=node&node=5000687&i=0>
>  Hello
>>  "This because I cannot remove the entities geometry column unless I
>> remove the entity table first.
>> And if I don't remove (or make invisible to qgis if possible) the
>> entities geometry column it slow down the qgis connection."
>>  Did you try to edit the view, using the where clause to exclude the
>> tables you don't want to be seen by postgis ?
>> Hugues.
>> *De :* [hidden email]<http://user/SendEmail.jtp?type=node&node=5000686&i=0>[mailto:[hidden
>> email] <http://user/SendEmail.jtp?type=node&node=5000686&i=1>] *De la
>> part de* Pietro Rossin
>> *Envoyé :* lundi 22 octobre 2012 09:25
>> *À :* [hidden email]<http://user/SendEmail.jtp?type=node&node=5000686&i=2>
>> to Qgis
>>  DELETE FROM geometry_columns WHERE f_table_name = 'puntigronda';
>> Query returned successfully: 0 rows affected, 0 ms execution time.
>> INSERT INTO geometry_columns (f_table_catalog,f_table_schema,
>> f_table_name, f_geometry_column, coord_dimension, srid,type)Â
>>  Â  VALUES ('','', 'puntigronda', 'the_geom', 3, 3004,'POINTS');
>> Query returned successfully: 0 rows affected, 16 ms execution time.
>> select relkind from pg_class where relname = 'geometry_columns';
>> returns:
>> "v"
>> What is this?
>> By the way
>> If my technique works, is it still better to explode the "entities" table
>> in one of this cases:
>> a) single layers
>> b) same kind of geometries
>> in both cases table permanent.
>> This because I cannot remove the entities geometry column unless I remove
>> Thanks for your help
>> Pietro
>> 2012/10/22 Sandro Santilli [via PostGIS] <[hidden email]<http://user/SendEmail.jtp?type=node&node=5000685&i=0>
>>> > Is there something wrong?
>>> What's wrong is that the "geometry_columns" table should be a view,
>>> in PostGIS-2.0. If it is a view, your DELETE and INSERT and UPDATE
>>> to it should have no effect.
>>> Can you verify this first ?
>>> The DELETE/INSERT/UPDATE commands all return the number of affected
>>> rows. If PostGIS is correctly installed you should alwyas get 0,
>>> no matter what you try to insert/delete/update.
>>> Also check:
>>> --strk;
>>>  http://www.cartodb.com - Map, analyze and build applications with
>>> your data
>>> Â  Â  Â  Â  Â  Â  Â  Â  Â  Â  Â  Â  Â  Â  Â  Â  Â  Â  Â  Â ~~
>>> http://strk.keybit.netÂ
>>> postgis-users mailing list
>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5000684&i=0>
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>  If you reply to this email, your message will be added to the
>>> discussion below:
>>> http://postgis.17.n6.nabble.com/How-to-make-some-geometry-column-visible-to-Qgis-tp5000570p5000684.html
>>> To unsubscribe from How to make some geometry column visible to Qgis, click
>>> here.
>>> NAML<http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> View this message in context: Re: How to make some geometry column
>> visible to Qgis<http://postgis.17.n6.nabble.com/How-to-make-some-geometry-column-visible-to-Qgis-tp5000570p5000685.html>
>> Sent from the PostGIS - User mailing list archive<http://postgis.17.n6.nabble.com/PostGIS-User-f3516033.html>at Nabble.com.
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5000686&i=3>
>> discussion below:
>> http://postgis.17.n6.nabble.com/How-to-make-some-geometry-column-visible-to-Qgis-tp5000570p5000686.html
>> here.
> visible to Qgis<http://postgis.17.n6.nabble.com/How-to-make-some-geometry-column-visible-to-Qgis-tp5000570p5000687.html>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121022/592868c2/attachment.html>
