[postgis-users] PostGIS 2 RPM
Bborie Park
bkpark at ucdavis.edu
Thu Oct 18 08:33:40 PDT 2012
Did you run "ldconfig" after adding the lib path to ld.so.conf?
-bborie
On 10/18/2012 08:20 AM, Jeff Lake wrote:
> Well that sounded promising
> but no joy,
> even tried --without-raster
> and got error's galore when I tried to apply postgis.sql to my tables
> *Jeff Lake*
> MichiganWxSystem <http://www.michiganwxsystem.com>
> AllisonHouse <http://www.allisonhouse.com>
> GRLevelXStuff <http://www.grlevelxstuff.com>
> On 10/18/2012 10:24, Bborie Park wrote:
>> It looks like the linker can't find libpq. You'll want to add the
>> following to /etc/ld.so.conf.
>> /usr/pgsql-9.1/lib
>> -bborie
>> On Thu, Oct 18, 2012 at 6:09 AM, Jeff Lake <jeff at michiganwxsystem.com>
>> wrote:
>>> Is there any reasoning why EL5 does not have a postGIS2_91 RPM ??
>>> this is on CentOS 5.8 64bit
>>> I have tried numerous times to install from source and keep getting
>>> raster
>>> error
>>> configure params
>>> ./configure --with-raster --with-pgconfig=/usr/pgsql-9.1/bin/pg_config
>>> --with-geosconfig=/geos-3.3.5/tools/geos-config
>>> PostGIS is now configured for x86_64-unknown-linux-gnu
>>> -------------- Compiler Info -------------
>>> C compiler: gcc -g -O2
>>> C++ compiler: g++ -g -O2
>>> SQL preprocessor: /usr/bin/cpp -traditional-cpp -P
>>> -------------- Dependencies --------------
>>> GEOS config: /geos-3.3.5/tools/geos-config
>>> GEOS version: 3.3.5
>>> GDAL config: /usr/local/bin/gdal-config
>>> GDAL version: 1.9.1
>>> PostgreSQL config: /usr/pgsql-9.1/bin/pg_config
>>> PostgreSQL version: PostgreSQL 9.1.6
>>> PROJ4 version: 48
>>> Libxml2 config: /usr/bin/xml2-config
>>> Libxml2 version: 2.6.26
>>> JSON-C support: no
>>> PostGIS debug level: 0
>>> Perl: /usr/bin/perl
>>> --------------- Extensions ---------------
>>> PostGIS Raster: enabled
>>> PostGIS Topology: enabled
>>> -------- Documentation Generation --------
>>> xsltproc: /usr/bin/xsltproc
>>> xsl style sheets:
>>> dblatex:
>>> convert: /usr/bin/convert
>>> mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
>>> Entering directory `/postgis-2.0.1/raster/loader'
>>> /bin/sh ../../libtool --mode=link gcc -g -O2 -fPIC -DPIC -Wall
>>> -Wmissing-prototypes -I../rt_core -I../../liblwgeom
>>> -I/usr/local/include
>>> -I/usr/local/include raster2pgsql.o ../rt_core/librtcore.a
>>> ../rt_core/librtcore.a ../../liblwgeom/liblwgeom.la -L/usr/local/lib
>>> -lgdal
>>> -L/usr/local/lib -lgeos_c -lc -lm -o raster2pgsql
>>> libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
>>> -I../rt_core -I../../liblwgeom -I/usr/local/include -I/usr/local/include
>>> raster2pgsql.o -o .libs/raster2pgsql ../rt_core/librtcore.a
>>> ../../liblwgeom/.libs/liblwgeom.so -L/usr/local/lib
>>> /usr/local/lib/libproj.so /usr/local/lib/libgdal.so -L/usr/lib64
>>> -L/usr/kerberos/lib64 -L/usr/lib64/mysql -lsqlite3
>>> /usr/lib64/libexpat.so
>>> -lgif -ljpeg -lpng -lpq -lcurl -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err
>>> -lidn -lz -lmysqlclient -lpthread -lrt -lssl -lcrypto -ldl
>>> /usr/local/lib/libgeos_c.so /usr/local/lib/libgeos.so -lc -lm -Wl,-rpath
>>> -Wl,/usr/local/lib -Wl,-rpath -Wl,/usr/lib64
>>> /usr/bin/ld: cannot find -lpq
>>> collect2: ld returned 1 exit status
>>> make[2]: *** [raster2pgsql] Error 1
>>> make[2]: Leaving directory `/postgis-2.0.1/raster/loader'
>>> make[1]: *** [rtloader] Error 2
>>> make[1]: Leaving directory `/postgis-2.0.1/raster'
>>> make: *** [all] Error 1
>>> Jeff Lake
>>> MichiganWxSystem
>>> AllisonHouse
>>> GRLevelXStuff
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
