[postgis-users] PostGIS 2 RPM
Jeff Lake
jeff at michiganwxsystem.com
Thu Oct 18 14:14:45 PDT 2012
Yes I did ..
#vim /etc/ld.so.conf
include /etc/ld.so.conf.d/*.conf
#dir /etc/ld.so.conf.d
atlas-x86_64.conf kernelcap-2.6.18-308.16.1.el5.conf mysql-x86_64.conf
xulrunner-32.conf
kernelcap-2.6.18-308.13.1.el5.conf mysqlclient15-x86_64.conf
postgresql-pgdg-libs.conf xulrunner-64.conf
#vim postgresql-pgdg-libs.conf
/usr/pgsql-9.1/lib
here is log files of configure and make
http://www2.michiganwxsystem.net/configure.log
http://www2.michiganwxsystem.net/make.log
*Jeff Lake*
MichiganWxSystem <http://www.michiganwxsystem.com>
AllisonHouse <http://www.allisonhouse.com>
GRLevelXStuff <http://www.grlevelxstuff.com>
On 10/18/2012 11:33, Bborie Park wrote:
> Did you run "ldconfig" after adding the lib path to ld.so.conf?
> -bborie
> On 10/18/2012 08:20 AM, Jeff Lake wrote:
>> Well that sounded promising
>> but no joy,
>> even tried --without-raster
>> and got error's galore when I tried to apply postgis.sql to my tables
>> *Jeff Lake*
>> On 10/18/2012 10:24, Bborie Park wrote:
>>> It looks like the linker can't find libpq. You'll want to add the
>>> following to /etc/ld.so.conf.
>>> /usr/pgsql-9.1/lib
>>> -bborie
>>> On Thu, Oct 18, 2012 at 6:09 AM, Jeff Lake <jeff at michiganwxsystem.com>
>>> wrote:
>>>> Is there any reasoning why EL5 does not have a postGIS2_91 RPM ??
>>>> this is on CentOS 5.8 64bit
>>>> I have tried numerous times to install from source and keep getting
>>>> raster
>>>> error
>>>> configure params
>>>> ./configure --with-raster --with-pgconfig=/usr/pgsql-9.1/bin/pg_config
>>>> --with-geosconfig=/geos-3.3.5/tools/geos-config
>>>> PostGIS is now configured for x86_64-unknown-linux-gnu
>>>> -------------- Compiler Info -------------
>>>> C compiler: gcc -g -O2
>>>> C++ compiler: g++ -g -O2
>>>> SQL preprocessor: /usr/bin/cpp -traditional-cpp -P
>>>> -------------- Dependencies --------------
>>>> GEOS config: /geos-3.3.5/tools/geos-config
>>>> GEOS version: 3.3.5
>>>> GDAL config: /usr/local/bin/gdal-config
>>>> GDAL version: 1.9.1
>>>> PostgreSQL config: /usr/pgsql-9.1/bin/pg_config
>>>> PostgreSQL version: PostgreSQL 9.1.6
>>>> PROJ4 version: 48
>>>> Libxml2 config: /usr/bin/xml2-config
>>>> Libxml2 version: 2.6.26
>>>> JSON-C support: no
>>>> PostGIS debug level: 0
>>>> Perl: /usr/bin/perl
>>>> --------------- Extensions ---------------
>>>> PostGIS Raster: enabled
>>>> PostGIS Topology: enabled
>>>> -------- Documentation Generation --------
>>>> xsltproc: /usr/bin/xsltproc
>>>> xsl style sheets:
>>>> dblatex:
>>>> convert: /usr/bin/convert
>>>> mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
>>>> Entering directory `/postgis-2.0.1/raster/loader'
>>>> /bin/sh ../../libtool --mode=link gcc -g -O2 -fPIC -DPIC -Wall
>>>> -Wmissing-prototypes -I../rt_core -I../../liblwgeom
>>>> -I/usr/local/include
>>>> -I/usr/local/include raster2pgsql.o ../rt_core/librtcore.a
>>>> ../rt_core/librtcore.a ../../liblwgeom/liblwgeom.la -L/usr/local/lib
>>>> -lgdal
>>>> -L/usr/local/lib -lgeos_c -lc -lm -o raster2pgsql
>>>> libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
>>>> -I../rt_core -I../../liblwgeom -I/usr/local/include -I/usr/local/include
>>>> raster2pgsql.o -o .libs/raster2pgsql ../rt_core/librtcore.a
>>>> ../../liblwgeom/.libs/liblwgeom.so -L/usr/local/lib
>>>> /usr/local/lib/libproj.so /usr/local/lib/libgdal.so -L/usr/lib64
>>>> -L/usr/kerberos/lib64 -L/usr/lib64/mysql -lsqlite3
>>>> /usr/lib64/libexpat.so
>>>> -lgif -ljpeg -lpng -lpq -lcurl -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err
>>>> -lidn -lz -lmysqlclient -lpthread -lrt -lssl -lcrypto -ldl
>>>> /usr/local/lib/libgeos_c.so /usr/local/lib/libgeos.so -lc -lm -Wl,-rpath
>>>> -Wl,/usr/local/lib -Wl,-rpath -Wl,/usr/lib64
>>>> /usr/bin/ld: cannot find -lpq
>>>> collect2: ld returned 1 exit status
>>>> make[2]: *** [raster2pgsql] Error 1
>>>> make[2]: Leaving directory `/postgis-2.0.1/raster/loader'
>>>> make[1]: *** [rtloader] Error 2
>>>> make[1]: Leaving directory `/postgis-2.0.1/raster'
>>>> make: *** [all] Error 1
>>>> Jeff Lake
>>>> MichiganWxSystem
>>>> AllisonHouse
>>>> GRLevelXStuff
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121018/eb309c32/attachment.html>
