[postgis-users] PostGIS 2 RPM
Bborie Park
bkpark at ucdavis.edu
Thu Oct 18 14:22:51 PDT 2012
Your initial email message indicated an error in the "raster/loader"
make step but that step has no errors in the make.log (bottom of the file).
-bborie
On 10/18/2012 02:14 PM, Jeff Lake wrote:
> Yes I did ..
> #vim /etc/ld.so.conf
> include /etc/ld.so.conf.d/*.conf
> #dir /etc/ld.so.conf.d
> atlas-x86_64.conf kernelcap-2.6.18-308.16.1.el5.conf mysql-x86_64.conf
> xulrunner-32.conf
> kernelcap-2.6.18-308.13.1.el5.conf mysqlclient15-x86_64.conf
> postgresql-pgdg-libs.conf xulrunner-64.conf
> #vim postgresql-pgdg-libs.conf
> /usr/pgsql-9.1/lib
> here is log files of configure and make
> http://www2.michiganwxsystem.net/configure.log
> http://www2.michiganwxsystem.net/make.log
> *Jeff Lake*
> MichiganWxSystem <http://www.michiganwxsystem.com>
> AllisonHouse <http://www.allisonhouse.com>
> GRLevelXStuff <http://www.grlevelxstuff.com>
> On 10/18/2012 11:33, Bborie Park wrote:
>> Did you run "ldconfig" after adding the lib path to ld.so.conf?
>> -bborie
>> On 10/18/2012 08:20 AM, Jeff Lake wrote:
>>> Well that sounded promising
>>> but no joy,
>>> even tried --without-raster
>>> and got error's galore when I tried to apply postgis.sql to my tables
>>> *Jeff Lake*
>>> On 10/18/2012 10:24, Bborie Park wrote:
>>>> It looks like the linker can't find libpq. You'll want to add the
>>>> following to /etc/ld.so.conf.
>>>> /usr/pgsql-9.1/lib
>>>> -bborie
>>>> On Thu, Oct 18, 2012 at 6:09 AM, Jeff Lake <jeff at michiganwxsystem.com>
>>>> wrote:
>>>>> Is there any reasoning why EL5 does not have a postGIS2_91 RPM ??
>>>>> this is on CentOS 5.8 64bit
>>>>> I have tried numerous times to install from source and keep getting
>>>>> raster
>>>>> error
>>>>> configure params
>>>>> ./configure --with-raster --with-pgconfig=/usr/pgsql-9.1/bin/pg_config
>>>>> --with-geosconfig=/geos-3.3.5/tools/geos-config
>>>>> PostGIS is now configured for x86_64-unknown-linux-gnu
>>>>> -------------- Compiler Info -------------
>>>>> C compiler: gcc -g -O2
>>>>> C++ compiler: g++ -g -O2
>>>>> SQL preprocessor: /usr/bin/cpp -traditional-cpp -P
>>>>> -------------- Dependencies --------------
>>>>> GEOS config: /geos-3.3.5/tools/geos-config
>>>>> GEOS version: 3.3.5
>>>>> GDAL config: /usr/local/bin/gdal-config
>>>>> GDAL version: 1.9.1
>>>>> PostgreSQL config: /usr/pgsql-9.1/bin/pg_config
>>>>> PostgreSQL version: PostgreSQL 9.1.6
>>>>> PROJ4 version: 48
>>>>> Libxml2 config: /usr/bin/xml2-config
>>>>> Libxml2 version: 2.6.26
>>>>> JSON-C support: no
>>>>> PostGIS debug level: 0
>>>>> Perl: /usr/bin/perl
>>>>> --------------- Extensions ---------------
>>>>> PostGIS Raster: enabled
>>>>> PostGIS Topology: enabled
>>>>> -------- Documentation Generation --------
>>>>> xsltproc: /usr/bin/xsltproc
>>>>> xsl style sheets:
>>>>> dblatex:
>>>>> convert: /usr/bin/convert
>>>>> mathml2.dtd:
>>>>> http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
>>>>> Entering directory `/postgis-2.0.1/raster/loader'
>>>>> /bin/sh ../../libtool --mode=link gcc -g -O2 -fPIC -DPIC -Wall
>>>>> -Wmissing-prototypes -I../rt_core -I../../liblwgeom
>>>>> -I/usr/local/include
>>>>> -I/usr/local/include raster2pgsql.o ../rt_core/librtcore.a
>>>>> ../rt_core/librtcore.a ../../liblwgeom/liblwgeom.la -L/usr/local/lib
>>>>> -lgdal
>>>>> -L/usr/local/lib -lgeos_c -lc -lm -o raster2pgsql
>>>>> libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
>>>>> -I../rt_core -I../../liblwgeom -I/usr/local/include
>>>>> raster2pgsql.o -o .libs/raster2pgsql ../rt_core/librtcore.a
>>>>> ../../liblwgeom/.libs/liblwgeom.so -L/usr/local/lib
>>>>> /usr/local/lib/libproj.so /usr/local/lib/libgdal.so -L/usr/lib64
>>>>> -L/usr/kerberos/lib64 -L/usr/lib64/mysql -lsqlite3
>>>>> /usr/lib64/libexpat.so
>>>>> -lgif -ljpeg -lpng -lpq -lcurl -lgssapi_krb5 -lkrb5 -lk5crypto
>>>>> -lcom_err
>>>>> -lidn -lz -lmysqlclient -lpthread -lrt -lssl -lcrypto -ldl
>>>>> /usr/local/lib/libgeos_c.so /usr/local/lib/libgeos.so -lc -lm
>>>>> -Wl,-rpath
>>>>> -Wl,/usr/local/lib -Wl,-rpath -Wl,/usr/lib64
>>>>> /usr/bin/ld: cannot find -lpq
>>>>> collect2: ld returned 1 exit status
>>>>> make[2]: *** [raster2pgsql] Error 1
>>>>> make[2]: Leaving directory `/postgis-2.0.1/raster/loader'
>>>>> make[1]: *** [rtloader] Error 2
>>>>> make[1]: Leaving directory `/postgis-2.0.1/raster'
>>>>> make: *** [all] Error 1
>>>>> Jeff Lake
>>>>> MichiganWxSystem
>>>>> AllisonHouse
>>>>> GRLevelXStuff
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
