[postgis-users] PostGIS 2 RPM
Jeff Lake
jeff at michiganwxsystem.com
Thu Oct 18 14:37:36 PDT 2012
the log doesnt show it,
but
#make > make.log
Can't fetch local revision (neither .svn nor .git found)
Not updating existing rev file at 9979
/usr/bin/ld: cannot find -lpq
collect2: ld returned 1 exit status
make[2]: *** [raster2pgsql] Error 1
make[1]: *** [rtloader] Error 2
make: *** [all] Error 1
*Jeff Lake*
MichiganWxSystem <http://www.michiganwxsystem.com>
AllisonHouse <http://www.allisonhouse.com>
GRLevelXStuff <http://www.grlevelxstuff.com>
On 10/18/2012 17:22, Bborie Park wrote:
> Your initial email message indicated an error in the "raster/loader"
> make step but that step has no errors in the make.log (bottom of the file).
> -bborie
> On 10/18/2012 02:14 PM, Jeff Lake wrote:
>> Yes I did ..
>> #vim /etc/ld.so.conf
>> include /etc/ld.so.conf.d/*.conf
>> #dir /etc/ld.so.conf.d
>> atlas-x86_64.conf kernelcap-2.6.18-308.16.1.el5.conf mysql-x86_64.conf
>> xulrunner-32.conf
>> kernelcap-2.6.18-308.13.1.el5.conf mysqlclient15-x86_64.conf
>> postgresql-pgdg-libs.conf xulrunner-64.conf
>> #vim postgresql-pgdg-libs.conf
>> /usr/pgsql-9.1/lib
>> here is log files of configure and make
>> http://www2.michiganwxsystem.net/configure.log
>> http://www2.michiganwxsystem.net/make.log
>> *Jeff Lake*
>> On 10/18/2012 11:33, Bborie Park wrote:
>>> Did you run "ldconfig" after adding the lib path to ld.so.conf?
>>> -bborie
>>> On 10/18/2012 08:20 AM, Jeff Lake wrote:
>>>> Well that sounded promising
>>>> but no joy,
>>>> even tried --without-raster
>>>> and got error's galore when I tried to apply postgis.sql to my tables
>>>> *Jeff Lake*
>>>> On 10/18/2012 10:24, Bborie Park wrote:
>>>>> It looks like the linker can't find libpq. You'll want to add the
>>>>> following to /etc/ld.so.conf.
>>>>> /usr/pgsql-9.1/lib
>>>>> -bborie
>>>>> On Thu, Oct 18, 2012 at 6:09 AM, Jeff Lake <jeff at michiganwxsystem.com>
>>>>> wrote:
>>>>>> Is there any reasoning why EL5 does not have a postGIS2_91 RPM ??
>>>>>> this is on CentOS 5.8 64bit
>>>>>> I have tried numerous times to install from source and keep getting
>>>>>> raster
>>>>>> error
>>>>>> configure params
>>>>>> ./configure --with-raster --with-pgconfig=/usr/pgsql-9.1/bin/pg_config
>>>>>> --with-geosconfig=/geos-3.3.5/tools/geos-config
>>>>>> PostGIS is now configured for x86_64-unknown-linux-gnu
>>>>>> -------------- Compiler Info -------------
>>>>>> C compiler: gcc -g -O2
>>>>>> C++ compiler: g++ -g -O2
>>>>>> SQL preprocessor: /usr/bin/cpp -traditional-cpp -P
>>>>>> -------------- Dependencies --------------
>>>>>> GEOS config: /geos-3.3.5/tools/geos-config
>>>>>> GEOS version: 3.3.5
>>>>>> GDAL config: /usr/local/bin/gdal-config
>>>>>> GDAL version: 1.9.1
>>>>>> PostgreSQL config: /usr/pgsql-9.1/bin/pg_config
>>>>>> PostgreSQL version: PostgreSQL 9.1.6
>>>>>> PROJ4 version: 48
>>>>>> Libxml2 config: /usr/bin/xml2-config
>>>>>> Libxml2 version: 2.6.26
>>>>>> JSON-C support: no
>>>>>> PostGIS debug level: 0
>>>>>> Perl: /usr/bin/perl
>>>>>> --------------- Extensions ---------------
>>>>>> PostGIS Raster: enabled
>>>>>> PostGIS Topology: enabled
>>>>>> -------- Documentation Generation --------
>>>>>> xsltproc: /usr/bin/xsltproc
>>>>>> xsl style sheets:
>>>>>> dblatex:
>>>>>> convert: /usr/bin/convert
>>>>>> mathml2.dtd:
>>>>>> http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
>>>>>> Entering directory `/postgis-2.0.1/raster/loader'
>>>>>> /bin/sh ../../libtool --mode=link gcc -g -O2 -fPIC -DPIC -Wall
>>>>>> -Wmissing-prototypes -I../rt_core -I../../liblwgeom
>>>>>> -I/usr/local/include
>>>>>> -I/usr/local/include raster2pgsql.o ../rt_core/librtcore.a
>>>>>> ../rt_core/librtcore.a ../../liblwgeom/liblwgeom.la -L/usr/local/lib
>>>>>> -lgdal
>>>>>> -L/usr/local/lib -lgeos_c -lc -lm -o raster2pgsql
>>>>>> libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
>>>>>> -I../rt_core -I../../liblwgeom -I/usr/local/include
>>>>>> raster2pgsql.o -o .libs/raster2pgsql ../rt_core/librtcore.a
>>>>>> ../../liblwgeom/.libs/liblwgeom.so -L/usr/local/lib
>>>>>> /usr/local/lib/libproj.so /usr/local/lib/libgdal.so -L/usr/lib64
>>>>>> -L/usr/kerberos/lib64 -L/usr/lib64/mysql -lsqlite3
>>>>>> /usr/lib64/libexpat.so
>>>>>> -lgif -ljpeg -lpng -lpq -lcurl -lgssapi_krb5 -lkrb5 -lk5crypto
>>>>>> -lcom_err
>>>>>> -lidn -lz -lmysqlclient -lpthread -lrt -lssl -lcrypto -ldl
>>>>>> /usr/local/lib/libgeos_c.so /usr/local/lib/libgeos.so -lc -lm
>>>>>> -Wl,-rpath
>>>>>> -Wl,/usr/local/lib -Wl,-rpath -Wl,/usr/lib64
>>>>>> make[2]: Leaving directory `/postgis-2.0.1/raster/loader'
>>>>>> make[1]: Leaving directory `/postgis-2.0.1/raster'
>>>>>> Jeff Lake
>>>>>> MichiganWxSystem
>>>>>> AllisonHouse
>>>>>> GRLevelXStuff
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> postgis-users at postgis.refractions.net
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121018/564a9c8a/attachment.html>
