[postgis-users] Question: calculating the slope with PostGIS 2.0
Pierre LACROIX piotrlacroix at gmail.com
Thu Oct 18 12:14:36 PDT 2012
I would like to generate the slope from a DEM.
The DEM is called Raster1. It has one band and holds integer values.
>From the the SQL Editor (in the PG Admin) the following command displays
values but does not generate an output slope raster:
SELECT ST_Slope(rast, 1,'Integer') from Raster1;
What is the syntax to generate the slope raster?
Thanks in advance.
Pierre
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121018/9ffb700f/attachment.html>
