[postgis-users] Question: calculating the slope with PostGIS 2.0
Bborie Park bkpark at ucdavis.edu
Thu Oct 18 12:18:57 PDT 2012
Pierre,
The pixel type isn't 'Integer'.  The list of valid pixel types are:
    1BB - 1-bit boolean
    2BUI - 2-bit unsigned integer
    4BUI - 4-bit unsigned integer
    8BSI - 8-bit signed integer
    8BUI - 8-bit unsigned integer
    16BSI - 16-bit signed integer
    16BUI - 16-bit unsigned integer
    32BSI - 32-bit signed integer
    32BUI - 32-bit unsigned integer
    32BF - 32-bit float
    64BF - 64-bit float
So, you'd call ST_Slope() with something like.
SELECT ST_Slope(rast, 1, '32BUI') from Raster1;
-bborie
On 10/18/2012 12:14 PM, Pierre LACROIX wrote:
> Hi,
> I would like to generate the slope from a DEM.
> The DEM is called Raster1. It has one band and holds integer values.
>>From the the SQL Editor (in the PG Admin) the following command displays
> values but does not generate an output slope raster:
> SELECT ST_Slope(rast, 1,'Integer') from Raster1;
> What is the syntax to generate the slope raster?
> Thanks in advance.
> Pierre
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
