[postgis-users] Question: calculating the slope with PostGIS 2.0
Pierre LACROIX
piotrlacroix at gmail.com
Fri Oct 19 06:42:20 PDT 2012
Thanks.
Does that create a new slope raster in the database?
After refreshing there is nothing new.
2012/10/18 Bborie Park <bkpark at ucdavis.edu>
> Pierre,
> The pixel type isn't 'Integer'. The list of valid pixel types are:
> 1BB - 1-bit boolean
> 2BUI - 2-bit unsigned integer
> 4BUI - 4-bit unsigned integer
> 8BSI - 8-bit signed integer
> 8BUI - 8-bit unsigned integer
> 16BSI - 16-bit signed integer
> 16BUI - 16-bit unsigned integer
> 32BSI - 32-bit signed integer
> 32BUI - 32-bit unsigned integer
> 32BF - 32-bit float
> 64BF - 64-bit float
> So, you'd call ST_Slope() with something like.
> SELECT ST_Slope(rast, 1, '32BUI') from Raster1;
> -bborie
> On 10/18/2012 12:14 PM, Pierre LACROIX wrote:
> > Hi,
> > I would like to generate the slope from a DEM.
> > The DEM is called Raster1. It has one band and holds integer values.
> >>From the the SQL Editor (in the PG Admin) the following command displays
> > values but does not generate an output slope raster:
> > SELECT ST_Slope(rast, 1,'Integer') from Raster1;
> > What is the syntax to generate the slope raster?
> > Thanks in advance.
> > Pierre
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Bborie Park
> Programmer
> Center for Vectorborne Diseases
> UC Davis
> 530-752-8380
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121019/eeba4f65/attachment.html>
