[postgis-users] Question: calculating the slope with PostGIS 2.0
Pierre LACROIX
piotrlacroix at gmail.com
Fri Oct 19 09:08:34 PDT 2012
Done.Thanks a lot.
2012/10/19 Francois Hugues <hugues.francois at irstea.fr>
> This is a select query. If you want to create a new table try
> Create table mytable as
> Myselect
> Hugues
> -------- Message d'origine--------
> De: postgis-users-bounces at postgis.refractions.net de la part de Pierre
> LACROIX
> Date: ven. 19/10/2012 15:42
> À: PostGIS Users Discussion
> Objet : Re: [postgis-users] Question: calculating the slope with PostGIS
> 2.0
> Thanks.
> Does that create a new slope raster in the database?
> After refreshing there is nothing new.
> 2012/10/18 Bborie Park <bkpark at ucdavis.edu>
> > Pierre,
> > The pixel type isn't 'Integer'. The list of valid pixel types are:
> > 1BB - 1-bit boolean
> > 2BUI - 2-bit unsigned integer
> > 4BUI - 4-bit unsigned integer
> > 8BSI - 8-bit signed integer
> > 8BUI - 8-bit unsigned integer
> > 16BSI - 16-bit signed integer
> > 16BUI - 16-bit unsigned integer
> > 32BSI - 32-bit signed integer
> > 32BUI - 32-bit unsigned integer
> > 32BF - 32-bit float
> > 64BF - 64-bit float
> > So, you'd call ST_Slope() with something like.
> > SELECT ST_Slope(rast, 1, '32BUI') from Raster1;
> > -bborie
> > On 10/18/2012 12:14 PM, Pierre LACROIX wrote:
> > > Hi,
> > > I would like to generate the slope from a DEM.
> > > The DEM is called Raster1. It has one band and holds integer values.
> > >>From the the SQL Editor (in the PG Admin) the following command
> displays
> > > values but does not generate an output slope raster:
> > > SELECT ST_Slope(rast, 1,'Integer') from Raster1;
> > > What is the syntax to generate the slope raster?
> > > Thanks in advance.
> > > Pierre
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > Bborie Park
> > Programmer
> > Center for Vectorborne Diseases
> > UC Davis
> > 530-752-8380
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121019/5f872bcb/attachment.html>
