[postgis-users] PostGIS 2 RPM
Jeff Lake
jeff at michiganwxsystem.com
Fri Oct 19 11:54:04 PDT 2012
I was just going to ask if I should rebuild GDAL
GDAL was built before 9.1.6 was ...
*Jeff Lake*
MichiganWxSystem <http://www.michiganwxsystem.com>
AllisonHouse <http://www.allisonhouse.com>
GRLevelXStuff <http://www.grlevelxstuff.com>
On 10/19/2012 14:48, Bborie Park wrote:
> Was GDAL built against that 9.1.6 RPM? I've committed some changes for
> 2.0 branch in r10484 so feel free to use that. That'll ame sure the
> linking goes correctly.
> I was expecting that your output of gdal-config --dep-libs would include
> a -L to the your libpq since your libpq is in /usr/pgsql-9.1/lib/
> -bborie
> On 10/19/2012 11:44 AM, Jeff Lake wrote:
>> GDAL was built from source (1.9.1)
>> PostgreSQL (-contrib|-server|-devel|-libs) were built from RPM's (9.1.6)
>> *Jeff Lake*
>> On 10/19/2012 14:36, Bborie Park wrote:
>>> Are the versions of GDAL and PostgreSQL from packages or ones you built?
>>> Thanks for providing all the feedback... I'm trying to see what the best
>>> way to fix this is.
>>> -bborie
>>> On 10/19/2012 11:31 AM, Jeff Lake wrote:
>>>> [root at ldm /]# gdal-config --dep-libs
>>>> -L/usr/lib64 -lgeos_c -lsqlite3 -lexpat -lgif -ljpeg -lpng -L/usr/lib64
>>>> -lpq -lz -lpthread -lm -lrt -ldl -L/usr/kerberos/lib64 -lcurl -ldl
>>>> -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lidn -lssl -lcrypto -lz
>>>> -L/usr/lib64/mysql -lmysqlclient -lpthread -lm -lrt -lssl -lcrypto -ldl
>>>> *Jeff Lake*
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121019/99210145/attachment.html>
