[postgis-users] PostGIS 2 RPM
Bborie Park
bkpark at ucdavis.edu
Fri Oct 19 11:57:25 PDT 2012
So, GDAL was built using the prior PostgreSQL (8.4 series). I wonder
what happens if you call "gdalinfo" without any arguments. Usually,
there will be error messages about missing libraries if what GDAL was
built against is missing. If you're not getting any error messages,
just use the changed Makefile.in from r10484
-bborie
On 10/19/2012 11:54 AM, Jeff Lake wrote:
> I was just going to ask if I should rebuild GDAL
> GDAL was built before 9.1.6 was ...
> *Jeff Lake*
> MichiganWxSystem <http://www.michiganwxsystem.com>
> AllisonHouse <http://www.allisonhouse.com>
> GRLevelXStuff <http://www.grlevelxstuff.com>
> On 10/19/2012 14:48, Bborie Park wrote:
>> Was GDAL built against that 9.1.6 RPM? I've committed some changes for
>> 2.0 branch in r10484 so feel free to use that. That'll ame sure the
>> linking goes correctly.
>> I was expecting that your output of gdal-config --dep-libs would include
>> a -L to the your libpq since your libpq is in /usr/pgsql-9.1/lib/
>> -bborie
>> On 10/19/2012 11:44 AM, Jeff Lake wrote:
>>> GDAL was built from source (1.9.1)
>>> PostgreSQL (-contrib|-server|-devel|-libs) were built from RPM's (9.1.6)
>>> *Jeff Lake*
>>> On 10/19/2012 14:36, Bborie Park wrote:
>>>> Are the versions of GDAL and PostgreSQL from packages or ones you
>>>> built?
>>>> Thanks for providing all the feedback... I'm trying to see what the
>>>> best
>>>> way to fix this is.
>>>> -bborie
>>>> On 10/19/2012 11:31 AM, Jeff Lake wrote:
>>>>> [root at ldm /]# gdal-config --dep-libs
>>>>> -L/usr/lib64 -lgeos_c -lsqlite3 -lexpat -lgif -ljpeg -lpng
>>>>> -L/usr/lib64
>>>>> -lpq -lz -lpthread -lm -lrt -ldl -L/usr/kerberos/lib64 -lcurl -ldl
>>>>> -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lidn -lssl -lcrypto -lz
>>>>> -L/usr/lib64/mysql -lmysqlclient -lpthread -lm -lrt -lssl -lcrypto
>>>>> -ldl
>>>>> *Jeff Lake*
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
