[postgis-users] PostGIS 2 RPM
Jeff Lake
jeff at michiganwxsystem.com
Fri Oct 19 14:26:11 PDT 2012
the Makefile from r10484 gets rid of the original error
can I build postGIS without-mysql ??
didn't even know mysql was an option
cause now I get ...
/usr/bin/ld: cannot find -lmysqlclient
collect2: ld returned 1 exit status
make[2]: *** [raster2pgsql] Error 1
make[2]: Leaving directory `/postgis-2.0.1/raster/loader'
make[1]: *** [rtloader] Error 2
make[1]: Leaving directory `/postgis-2.0.1/raster'
make: *** [all] Error 1
*Jeff Lake*
MichiganWxSystem <http://www.michiganwxsystem.com>
AllisonHouse <http://www.allisonhouse.com>
GRLevelXStuff <http://www.grlevelxstuff.com>
On 10/19/2012 14:57, Bborie Park wrote:
> So, GDAL was built using the prior PostgreSQL (8.4 series). I wonder
> what happens if you call "gdalinfo" without any arguments. Usually,
> there will be error messages about missing libraries if what GDAL was
> built against is missing. If you're not getting any error messages,
> just use the changed Makefile.in from r10484
> -bborie
> On 10/19/2012 11:54 AM, Jeff Lake wrote:
>> I was just going to ask if I should rebuild GDAL
>> GDAL was built before 9.1.6 was ...
>> *Jeff Lake*
>> On 10/19/2012 14:48, Bborie Park wrote:
>>> Was GDAL built against that 9.1.6 RPM? I've committed some changes for
>>> 2.0 branch in r10484 so feel free to use that. That'll ame sure the
>>> linking goes correctly.
>>> I was expecting that your output of gdal-config --dep-libs would include
>>> a -L to the your libpq since your libpq is in /usr/pgsql-9.1/lib/
>>> -bborie
>>> On 10/19/2012 11:44 AM, Jeff Lake wrote:
>>>> GDAL was built from source (1.9.1)
>>>> PostgreSQL (-contrib|-server|-devel|-libs) were built from RPM's (9.1.6)
>>>> *Jeff Lake*
>>>> On 10/19/2012 14:36, Bborie Park wrote:
>>>>> Are the versions of GDAL and PostgreSQL from packages or ones you
>>>>> built?
>>>>> Thanks for providing all the feedback... I'm trying to see what the
>>>>> best
>>>>> way to fix this is.
>>>>> -bborie
>>>>> On 10/19/2012 11:31 AM, Jeff Lake wrote:
>>>>>> [root at ldm /]# gdal-config --dep-libs
>>>>>> -L/usr/lib64 -lgeos_c -lsqlite3 -lexpat -lgif -ljpeg -lpng
>>>>>> -L/usr/lib64
>>>>>> -lpq -lz -lpthread -lm -lrt -ldl -L/usr/kerberos/lib64 -lcurl -ldl
>>>>>> -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lidn -lssl -lcrypto -lz
>>>>>> -L/usr/lib64/mysql -lmysqlclient -lpthread -lm -lrt -lssl -lcrypto
>>>>>> -ldl
>>>>>> *Jeff Lake*
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> postgis-users at postgis.refractions.net
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121019/b8727e3b/attachment.html>
