[postgis-users] Insert data based on XML schema
babou
hiba.maalaoui at gmail.com
Fri Oct 19 16:38:18 PDT 2012
hi,
I have CityGML file, and now I want to export the file in txt format (xml,
gml, citymgl) in a 3D database,
can you tell me how you created the required tables in the database?
thank you for any help :)
View this message in context: http://postgis.17.n6.nabble.com/Insert-data-based-on-XML-schema-tp3558396p5000646.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
