[postgis-users] CityGML in PostGIS - 3D City Database released
Felix Kunde
felix-kunde at gmx.de
Mon Oct 22 10:28:37 PDT 2012
Yes it is possible. Just download the newest setup from here
<http://opportunity.bv.tu-berlin.de/software/projects/3dcitydb-imp-exp/files>
Check out the tutorial pdf how to set up the relational schema (tables etc.)
for the 3d city database.
If your database is ready to be filled with CityGML data you can run the
Importer/Exporter tool
and start the import of your files (xml, gml, citygml, txt). The import
process can take some time
depending of the size of your data. Ranging from a few seconds (couple of
buildings) to some hours
(city model of an entire city).
View this message in context: http://postgis.17.n6.nabble.com/CityGML-in-PostGIS-3D-City-Database-released-tp4998980p5000696.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
