[postgis-users] PostGIS 2 RPM
Bborie Park
bkpark at ucdavis.edu
Fri Oct 19 19:00:30 PDT 2012
Can you rebuild your GDAL? I'm going to have to poke a few machines
to see how they all respond to gdal-config --dep-libs
-bborie
On Fri, Oct 19, 2012 at 6:38 PM, Jeff Lake <jeff at michiganwxsystem.com> wrote:
> I appreciate the assistance.
> but seeings how GDAL only supports libmysql15, and the latest is libmysql18
> I can't build GDAL against it, and hence postGIS 2.0 fails
> I'm really not in the mood to go backwards with mySQL and/or libmysql
> just to obtain the little I will
> (already been though this with GDAL .. I can see supporting libmysql15 + not
> JUST 15
> Jeff Lake
> MichiganWxSystem
> AllisonHouse
> GRLevelXStuff
> On 10/19/2012 14:57, Bborie Park wrote:
> So, GDAL was built using the prior PostgreSQL (8.4 series). I wonder
> what happens if you call "gdalinfo" without any arguments. Usually,
> there will be error messages about missing libraries if what GDAL was
> built against is missing. If you're not getting any error messages,
> just use the changed Makefile.in from r10484
> -bborie
> On 10/19/2012 11:54 AM, Jeff Lake wrote:
> I was just going to ask if I should rebuild GDAL
> GDAL was built before 9.1.6 was ...
> *Jeff Lake*
> MichiganWxSystem <http://www.michiganwxsystem.com>
> AllisonHouse <http://www.allisonhouse.com>
> GRLevelXStuff <http://www.grlevelxstuff.com>
> On 10/19/2012 14:48, Bborie Park wrote:
> Was GDAL built against that 9.1.6 RPM? I've committed some changes for
> 2.0 branch in r10484 so feel free to use that. That'll ame sure the
> linking goes correctly.
> I was expecting that your output of gdal-config --dep-libs would include
> a -L to the your libpq since your libpq is in /usr/pgsql-9.1/lib/
> -bborie
> On 10/19/2012 11:44 AM, Jeff Lake wrote:
> GDAL was built from source (1.9.1)
> PostgreSQL (-contrib|-server|-devel|-libs) were built from RPM's (9.1.6)
> *Jeff Lake*
> On 10/19/2012 14:36, Bborie Park wrote:
> Are the versions of GDAL and PostgreSQL from packages or ones you
> built?
> Thanks for providing all the feedback... I'm trying to see what the
> best
> way to fix this is.
> -bborie
> On 10/19/2012 11:31 AM, Jeff Lake wrote:
> [root at ldm /]# gdal-config --dep-libs
> -L/usr/lib64 -lgeos_c -lsqlite3 -lexpat -lgif -ljpeg -lpng
> -L/usr/lib64
> -lpq -lz -lpthread -lm -lrt -ldl -L/usr/kerberos/lib64 -lcurl -ldl
> -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lidn -lssl -lcrypto -lz
> -L/usr/lib64/mysql -lmysqlclient -lpthread -lm -lrt -lssl -lcrypto
> -ldl
> *Jeff Lake*
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
