[postgis-users] PostGIS 2 RPM
Jeff Lake jeff at michiganwxsystem.com
Fri Oct 19 19:06:42 PDT 2012
I tried
but because I have upgraded libmysql and mySQL after I first built GDAL
GDAL fails I imagine if I go back a few versions on libmysql and mySQL to
the required libmysql.15 GDAL will install no problem
*Jeff Lake*
MichiganWxSystem <http://www.michiganwxsystem.com>
AllisonHouse <http://www.allisonhouse.com>
GRLevelXStuff <http://www.grlevelxstuff.com>
On 10/19/2012 22:00, Bborie Park wrote:
> Can you rebuild your GDAL?  I'm going to have to poke a few machines
> to see how they all respond to gdal-config --dep-libs
> -bborie
> On Fri, Oct 19, 2012 at 6:38 PM, Jeff Lake <jeff at michiganwxsystem.com> wrote:
>> I appreciate the assistance.
>> but seeings how GDAL only supports libmysql15, and the latest is libmysql18
>> I can't build GDAL against it, and hence postGIS 2.0 fails
>> I'm really not in the mood to go backwards with mySQL and/or libmysql
>> just to obtain the little I will
>> (already been though this with GDAL .. I can see supporting libmysql15 + not
>> JUST 15
>> Jeff Lake
>> MichiganWxSystem
>> AllisonHouse
>> GRLevelXStuff
>> On 10/19/2012 14:57, Bborie Park wrote:
>> So, GDAL was built using the prior PostgreSQL (8.4 series).  I wonder
>> what happens if you call "gdalinfo" without any arguments.  Usually,
>> there will be error messages about missing libraries if what GDAL was
>> built against is missing.  If you're not getting any error messages,
>> just use the changed Makefile.in from r10484
>> -bborie
>> On 10/19/2012 11:54 AM, Jeff Lake wrote:
>> I was just going to ask if I should rebuild GDAL
>> GDAL was built before 9.1.6 was ...
>> *Jeff Lake*
>> On 10/19/2012 14:48, Bborie Park wrote:
>> Was GDAL built against that 9.1.6 RPM?  I've committed some changes for
>> 2.0 branch in r10484 so feel free to use that.  That'll ame sure the
>> linking goes correctly.
>> I was expecting that your output of gdal-config --dep-libs would include
>> a -L to the your libpq since your libpq is in /usr/pgsql-9.1/lib/
>> -bborie
>> On 10/19/2012 11:44 AM, Jeff Lake wrote:
>> GDAL was built from source (1.9.1)
>> PostgreSQL (-contrib|-server|-devel|-libs) were built from RPM's (9.1.6)
>> *Jeff Lake*
>> On 10/19/2012 14:36, Bborie Park wrote:
>> Are the versions of GDAL and PostgreSQL from packages or ones you
>> built?
>> Thanks for providing all the feedback... I'm trying to see what the
>> best
>> way to fix this is.
>> -bborie
>> On 10/19/2012 11:31 AM, Jeff Lake wrote:
>> [root at ldm /]# gdal-config --dep-libs
>> -L/usr/lib64 -lgeos_c -lsqlite3 -lexpat -lgif -ljpeg -lpng
>> -L/usr/lib64
>> -lpq -lz -lpthread -lm -lrt -ldl -L/usr/kerberos/lib64 -lcurl -ldl
>> -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lidn -lssl -lcrypto -lz
>> -L/usr/lib64/mysql -lmysqlclient -lpthread -lm -lrt -lssl -lcrypto
>> -ldl
>> *Jeff Lake*
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121019/c8b1b1ac/attachment.html>
