[postgis-users] hierarchical topology and attributes at different levels
Sandro Santilli
strk at keybit.net
Sun Oct 21 12:40:28 PDT 2012
On Fri, Oct 19, 2012 at 11:56:18AM -0500, William Kyngesburye wrote:
> Can the attributes of child layers be seen from a layer?
Sure, given enough neurons to build the appropriate SQL query...
(TopoGeomeometry management still has rough edges)
It would be something like this:
SELECT * FROM child_features c, parent_features s
WHERE id(c.topogeom) = GetTopoGeomElements(s.topogeom)[2];
Fixing the syntax is left as an excercise to the reader
--strk;
http://www.cartodb.com - Map, analyze and build applications with your data
~~ http://strk.keybit.net
