[postgis-users] hierarchical topology and attributes at different levels
William Kyngesburye woklist at kyngchaos.com
Mon Oct 22 19:51:30 PDT 2012
On Oct 21, 2012, at 2:40 PM, Sandro Santilli wrote:
> On Fri, Oct 19, 2012 at 11:56:18AM -0500, William Kyngesburye wrote:
>> Can the attributes of child layers be seen from a layer?
> Sure, given enough neurons to build the appropriate SQL query...
> (TopoGeomeometry management still has rough edges)
Yes, this has been taxing my neurons ;)
> It would be something like this:
> SELECT * FROM child_features c, parent_features s
> WHERE id(c.topogeom) = GetTopoGeomElements(s.topogeom)[2];
> Fixing the syntax is left as an excercise to the reader
For now I'm interested in the possibilities.  I'm working on how I want to structure it and how to get the data in first.  I can get the base level of polys into topology, but I need to figure out how to connect higher level existing polygon data to the child levels (the states which are constructed from counties).  I guess when I figure that out, I'll know a lot more about how to do the query linking child-parent attributes.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
