[postgis-users] How to make some geometry column visible to Qgis
Pietro Rossin pierigis at gmail.com
Mon Oct 22 00:24:34 PDT 2012
DELETE FROM geometry_columns WHERE f_table_name = 'puntigronda';
Query returned successfully: 0 rows affected, 0 ms execution time.
INSERT INTO geometry_columns (f_table_catalog,f_table_schema, f_table_name,
f_geometry_column, coord_dimension, srid,type)
  VALUES ('','', 'puntigronda', 'the_geom', 3, 3004,'POINTS');
Query returned successfully: 0 rows affected, 16 ms execution time.
select relkind from pg_class where relname = 'geometry_columns';
returns:
"v"
What is this?
By the way
If my technique works, is it still better to explode the "entities" table
in one of this cases:
a) single layers
b) same kind of geometries
in both cases table permanent.
This because I cannot remove the entities geometry column unless I remove
the entity table first.
And if I don't remove (or make invisible to qgis if possible) the entities
geometry column it slow down the qgis connection.
Thanks for your help
Pietro
2012/10/22 Sandro Santilli [via PostGIS] <
ml-node+s17n5000684h28 at n6.nabble.com>
> > Is there something wrong?
> What's wrong is that the "geometry_columns" table should be a view,
> in PostGIS-2.0. If it is a view, your DELETE and INSERT and UPDATE
> to it should have no effect.
> Can you verify this first ?
> The DELETE/INSERT/UPDATE commands all return the number of affected
> rows. If PostGIS is correctly installed you should alwyas get 0,
> no matter what you try to insert/delete/update.
> Also check:
> --strk;
>  http://www.cartodb.com - Map, analyze and build applications with your
> data
>                                        ~~ http://strk.keybit.net
> postgis-users mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5000684&i=0>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://postgis.17.n6.nabble.com/How-to-make-some-geometry-column-visible-to-Qgis-tp5000570p5000684.html
>  To unsubscribe from How to make some geometry column visible to Qgis, click
> here<http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5000570&code=cGllcmlnaXNAZ21haWwuY29tfDUwMDA1NzB8MjMwODY1MTQ5>
> NAML<http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://postgis.17.n6.nabble.com/How-to-make-some-geometry-column-visible-to-Qgis-tp5000570p5000685.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121022/db948759/attachment.html>
